V6 Firebird ram air?
Old Jan 14, 2004 | 07:14 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Does this setup actually work? Can it be installed in a bird? Are these dual snorkels rare?
Old Jan 14, 2004 | 07:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
it works cause thats what I have, but no it will not work on a bird. Its also not "ram air", its dual snorkle.
They do make a ram air kit for firebirds, cost several hundreds. find redraif's car.
Old Jan 14, 2004 | 09:07 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
the dual snorkle intake is offa camaro, and most likely it's installed into a camaro. The Ram air stickers might be referring to the mod that can be done to camaro's to utalize the camaros front bumper and create ram air from it. The hood on the firebird slopes more, and the intake won't fit under a firebird hood, i know, i tried...depending on how thick the intake is though, you may possibilibly be able to grind it down a little bit, but i'd doubt the plastic is that thick. Think the Ram air unit that's avaiilble for our cars by SLP and others normally uses the ram air hood, sounds liek a good excuse to buy the ram air hood don't it?
Old Jan 14, 2004 | 09:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
$60$80 from year one or other 68-69 firebird hood scoops. metal with open centers. You can get plastic cheaper and closed [you drill em open] cheaper.
item=2454300610 on ebay is the right ones but to pricey for cheap plastic.
Old Jan 23, 2004 | 01:15 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
That's my car in the first post!!
And yes, it is a ram-air setup.
Here are more pics:
Old Jan 23, 2004 | 01:16 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
And no, it wont work on a firebird.
Old Apr 27, 2004 | 11:49 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
So what part of the hood squishes the intake?
If its the bar that goes across in front above ther rad, then it might be modifyable to alow the intake to go by.
I recall reading somewhere in here, the intake itself fits, it is merely an issue of the hood not closing.
Am I missing something else here?
Old Apr 27, 2004 | 12:20 PM
85f-bird's Avatar
Engine: 2.8L, LS1
no, ur not missing anything. The only reason that it doesn't fit is the fact that the hood won't close as a result of the firebird's sloping hood. if memory recalls corectly, the piece has to ride above the crossbrace for the radiator support, on birds the hood closes and really doesn't allow any room between the radiator support and the actual hood assembly, and it needs to lose maybe an inch of thicknesss, it's essentially the reason GM didn't put that designed intake on a bird, as we know they would have if they could've. i'm defiantely not saying that it can't be done, just don't know if the benefit would be worth the trouble, if you can find a wrecked ws6 car, you'd be probably be better off getting the intake from it, as it'll actually be the same as the slp styled intakes sold for our cars.
Old Apr 27, 2004 | 05:54 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
this set up will work on the sixer too??
Old Apr 27, 2004 | 06:16 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Here are more pics:
Nice sheet metal work!
Old Apr 27, 2004 | 11:23 PM
85f-bird's Avatar
Engine: 2.8L, LS1
the setup doesn't matter for engine size, as the v6 maros had them just as well as the v8 cars...the unit i have in my garage came from an 85-86 camaro v6....just didn't work on the bird, and i didn't really see the point in modding it to work, after all the cutting and reworking, it would no longer have much "wow, cool looking" appeal to it.
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
