I want to dress up........the car that is.
Old Apr 27, 2004 | 10:04 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Some of you might recall that I recently spent some $$ putting my wife's 92 3.1 Camaro RS back on the road after gathering dust in the garage for the last 3 years. I've shined her up, tinted the windows, did a bunch of needed mechanical work (only 70,000 original miles, my wife is the original owner - still have the window sticker even!).
Anyway, here's the little extra thing I want to do: I like the twin tailpipes but I wish you could see them. I think picking up a simple pair of chrome tips at PepBoys/Kragen/AutoZone would just look stupid since they have that downward turn at the end (as seen in attached image). Short of replacing the exhaust, which is in great shape, is there any way to accomplish this? Or should I just leave well enough alone?
Old Apr 27, 2004 | 10:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It looks nice, I'll assume what looks like damage from the door to the gas lid is light through the trees.
Id suggest you take it to a muffler shop and have them install some nice tips, bolt on parts store tips just look like crap.
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
if you buy some chrome tips that are like a foot long or so, you can turn the tailpipes down a little and cut them off before the bend then put your new chrome ones on. know what i mean?
Old Apr 28, 2004 | 01:47 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I agree with AM91Camaro_RS, or something along these lines.
Old Apr 28, 2004 | 04:26 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Aye. If it can be done by bending, great.. if not, chop the output pipes off either side of the muffler, chop off the turndowns, get them at an angle where they'll make a straight shot out with room to clear nice straight tips, and reweld.
Old Apr 28, 2004 | 12:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I did just that. I did not like how loud the exhaust sounded with the tips under the car. So I extended them out past the bumper to get the sound out from under the car. [ let the jerk behind me listen to it.]
I did just that, cut them off where they turned down so I could run the tip straight.
1st set of tips were the chrome dual split type. I had to add a short muffler adapter piece of pipe for more length. And I just used that 15 min JB weld to stick them in place. They stuck out a bit far but got all the sound out from under the car. Very quiet ride inside.
They worked well for a year or so but it seamed to project to much of the exhaust note behind me. Sounded like a turbo chicken. People could hear me a mile away.
So I then switch to a similar set of tips off an 80s gramdam grandprix something gm.
Any ways they still stick out past the bumper a tad but they have the backs cut out. So the sound is kind of equally dispersed between under the car and out the back. Give the car a more of a rumble sound than the turbo chicken sound.
http://www.viragotech.com/86bird/exhausttips.html
Old Apr 28, 2004 | 12:22 PM
Originally posted by Gumby
[B]...Sounded like a turbo chicken...
What's a turbo chicken?
Old Apr 28, 2004 | 12:34 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
IN those pics the first tips you had on there looked hideous, but i like the last pics there, looks 100000000000% better
1st
last
Old Apr 28, 2004 | 02:20 PM
Car: 1992 Camaro RS
Engine: 3.1L
That's correct, there is no damage to this car, just the usual paint chips and weather fade on the rear bumper. The car was parked outside for the first 7 years of its life. Too bad.
Gumby, that's more what I'm thinking. Well, the second pic anyway. No offense but I'm with 1986CamaroSC - I like the second pic much better. I'd opt for single tips on each side, but that's just me.
I appreciate the input guys. Looks like the way to go is have a muffler shop set something up right. Thanks!
Old Apr 28, 2004 | 04:56 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i've got the dual tip setup going on w/ the bird, it's kinda "historical"that birds have dual tips on each side, tta (dual tips, one side) 2nd gen t/a's. I'll have to see if i can find a pic of them, the one thing that i will say is, don't do what everyone else around these parts does, and slap some 3"exhaust tips on the camaro ,taht stick out 4 inches from the bumper...instaed of cool, they're really starting to look generic.
Old Apr 28, 2004 | 05:28 PM
Car: 1992 Camaro RS
Engine: 3.1L
Big fat exhaust tips sticking way out not only do NOT look cool but, well, can you say "****"????
WTF? You can't use the four letter word for Uncle Ben's or Minute R*ce on this board or it automatically gets edited????
Old Apr 28, 2004 | 08:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, people though that it was a racial slur, when it really wasn't, so they turned on censoring for rice.
First you should check to see if those turned-down ends are really round. You might not be able to bolt a tip onto them.
That's how (damn I just typed this to someone, why didn't I save it?!?!) the Dynomax super turbo catback is. They angle the ends of the pipes down, cut the ends into a slash-cut, and then slightly flatten the pipe at the end so it's a slight oval. A bolt-on tip won't slide over. A weld-on tip would require the welder to un-flatten the oval.
I put Megs chrome rolled edge tips on my car. They're bolt-on's, but only fit a 2" pipe- the Dynomax has 2.5" pipes. I used a tailipipe expander (see http://www.lislecorp.com/tool_detail.cfm?detail=468 ) to expand the tip's end to 2.5". Then I spun my bench vise shut, slid the tip's end over the jaws, and opened the vise to spread the tip's end to about 2.75".
Then I used a band clamp (see http://store.summitracing.com/partde...rt=WLK%2D33240 ) to attach the tip to the tailpipe. The clamp crushed the tip's end back to 2.5 so the tip wound up "wedged" in there.
I was able to cut the tailpipes with the pipes off of the car. But since yours are on there (and will be Held on there with years of corrosion), it might be hard to get a hacksaw in there, and it might be hard to get a decent straight cut. So... you can pick up this tool: http://www.lislecorp.com/tool_detail.cfm?detail=454 It works great, and you can get a nice straight cut. (Off topic- how the HELL is that also a strut cut-off tool? A strut would explode!)
Now.. if you've got the room, you might be able to loosen up the tailpipes. This would be similar to replacing a catalytic convertor. You'll need to cut the muffler outlet flanges parallel to the pipe. Crap, I should draw a pic of this. Okay, I will... done.
After you make the cut (indicated in red), use a cold chisel ($1.00 at Sears) and hammer to bang along the cut, and spread it open. Eventually you'll be able to wiggle the pipe free. When you're reassembling everything, an exhaust clamp will put the slip-fit flange back to normal shape.
Attached Thumbnails I want to dress up........the car that is.-how2-openflange-tomp.jpg
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
kah992
Aug 19, 2015 02:55 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
