Need Strut Tower Brace for 84 V6 Camaro
Old Jan 14, 2004 | 10:38 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
Hey, I got some advice from Gumby earlier on a Strut tower brace, but wanted to find out what some other people thought too. I had a particular design type in mind to use, but if I can't locate one then I'll have to settle for the Jamex that Gumby recommended.
The type that I want is similar to the Edelbrock 5226 or 5227. It's triangular in shape, and connects the strut towers to the firewall as well as spanning across the engine bay.
The other thing is that I am not sure that a Jamex will clear my air cleaner assy as well as it does the MPFI apparatus on cars like Gumby's.
Any advice an experience on both types of braces would be greatly appreciated. I think it sucks that manufacturers make so many parts for V8 cars and SQUAT for V6 models.
Old Jan 15, 2004 | 04:37 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I have a BMR STB in my Camaro. I added shims on both sides to clear the TB and A/C.
Old Jan 15, 2004 | 05:02 PM
Car: 1984 Camaro
How much does that style brace help for cornering ability? I haven't seen that particular style yet, where could I price one?
Old Jan 15, 2004 | 06:34 PM
Engine: 346ci LS1
Transmission: MN6
You can go here for all your answers!
http://www.bmrfabrication.com/F3-chassis.htm#strutbrace
Old Jan 15, 2004 | 08:51 PM
Car: 1984 Camaro
Hey man thanks for the help, but looking closer, I'm not sure that brace will work with a carbureted V6....it's made to fit over a TPI unit very nicely....but I think it'll hit the air cleaner nozzle. I think I may have to build one.....
Old Jan 19, 2004 | 09:41 PM
Faded's Avatar
Car: '91 Firebird
WWasem, that fit with no problems over your v6? I've heard our engines were too tall or something crazy like that?
Old Jan 20, 2004 | 09:39 AM
Car: 1984 Camaro
Yeah, the v6's are a 60-degree engine. V8's are 90, I believe; and because the angle between the cylinder heads is more spread out, the V8 sits lower in the engine bay.
The 6 is nice for fuel economy and that's about it. It's not great for performance, gets no respect, and you can't accessorize them NEARLY as much as you can the V8's.
Old Jan 20, 2004 | 09:54 AM
Engine: 346ci LS1
Transmission: MN6
Here is a picture of one of the shims. They aren't very big, and the hood still clears fine.
Old Jan 20, 2004 | 09:59 AM
Engine: 346ci LS1
Transmission: MN6
With the combination of the wonderbar I believe it helped the corning quite a bit by boxing up the front end.
Here's a picture of the wonderbar. (Not to be confused with wonderbra )
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Ian Irvine
Sep 4, 2015 08:08 AM
