First ghetto bracket mock up
Old Jan 17, 2004 | 10:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Not pretty, but gets the job done.
This is the pass side, driver side going to be more interesting.
View 1
View 2
View 3
View 4
Comparo between 3800 bracket & new one
Yeah, and you thought the pvc intake was ghetto
edit: All three brackets lined up
The new one will be slightly longer than the 2.8 brackets, but has a bigger base and different mounting bolt locations.
Old Jan 18, 2004 | 01:57 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
hahaha, that is ghetto.
Old Jan 18, 2004 | 04:00 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
damn.. you're already competing with my passenger side manifold for '04 ghetto fabulous piece of the year.. keep up the good work
Old Jan 18, 2004 | 09:01 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
um, are you trying to start a fire under the hood on this one too j/k (trying to get ya back for the 90hp comment )
Looks like it needs some small fine tuning, but atleast it gives you an idea of whats needed.
Old Jan 18, 2004 | 02:36 PM
dennis6's Avatar
Car: 1991 Camaro RS
West Coast Fiero makes 3800 engine mounts for fieros. Maybe you could talk them into working with your to make them for thirdgens. You could get a quality mount out of it and everyone else would have a supplier for the parts.
http://www.westcoastfiero.com/mounts/mounts.html
Old Jan 18, 2004 | 03:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I understand why but wonder why? hehehe
Most people I know would of just set it in there with the stock 3800 mounts and welded them down where they touched.
Quick easy install.
Old Jan 18, 2004 | 03:40 PM
Fords Never Die's Avatar
Car: F-250 Crew Cab LB
Engine: 7.3L Turbo Diesel
Transmission: 6-Speed Manual
If you wanted to, you could actually send us an email at the shop, and let us know what you are looking for. As the gentleman said in the post above, we make mounts for everything dealing with the 3800 and the Fiero. If you actually either sent us the mounts you wanted done, or measurements, we wouldn't have a problem doing that. If you want, give me an email and we can talk about this further...
fords.never.die@fieros.westcoastfiero.com
Old Jan 18, 2004 | 05:44 PM
Engine: 5.7 / 7.4
Quick easy install.
That would be jsut as bad as trying to put in a 2.8~3.4 w/the 3.4 brackets on. It just will not work (properly or look good w/intake sitting 4inches above the hole cut in the hood.
Fords Never Die, I'm gonna improve the model, & do the drivers side next. Then, maybe.....
edit: You should also notic that my base for the mout is significantly smaller thatn the stock peice. The 4th gen driveline has brackets on either side that connect the tranny to the block. Most likel;y due to having to be installed as 1 assembly & not stressing out the bell housing bolts. Glad I don't have to worry about that
Old Jan 18, 2004 | 09:07 PM
Engine: 5.7 / 7.4
Not so ghetto ..........................
New & Improved 1
New & Improved 2
New & Improved 3
btw, DA PATS!!!!!!!!!!!!!!!!!!!!!!!!!!!
:lala: :lala: :lala:
Old Jan 19, 2004 | 06:13 AM
Dale's Avatar
Engine: 350 S-TPI
looks much better
Old Jan 19, 2004 | 06:39 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Originally posted by Dale
looks much better
yeah much better
Old Jan 19, 2004 | 10:12 PM
Engine: 5.7 / 7.4
Go the drivers side done today
http://www.camarov6.com/cgi-bin/ulti...c&f=8&t=004705 3.4 block, rods & ecm & harness for sale
any way, pics soon, and maybe even some bonus ones too
Old Jan 20, 2004 | 06:12 AM
Dale's Avatar
Engine: 350 S-TPI
boooyyy, you about made my face
Don't even want to know the words that were running thru my mind tell I clicked that link.
Old Jan 20, 2004 | 06:39 PM
Engine: 5.7 / 7.4
anywho,
Pass side test fit
Drivers side 1
Driver Side 2
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
