pcv hoses
Old Jan 27, 2004 | 07:06 PM
Slow2.8's Avatar
pcv hoses
i am the king of breaking hard hoses especially the emissions ones... well now ive managed to break the pcv hose that goes into the throttle body and the piece that connects the two is also broken ( behind the plenum ) i've looked at all junk yards for it but theyr'e stripped, any suggestions on how to get this part? or for a fix for it?
Old Jan 27, 2004 | 07:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I was lucky and had the lines from the 3.4 to use as spares.
save as much of the old lines as possible, & get new lines to splice inbetween.
Old Jan 27, 2004 | 07:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Reminds me of the 2.8/2.8 swap I helped my friend with... he snapped that large plastic hose. We rebuilt it with heater hose... check out the 10th picture at http://www.geocities.com/tomp_3rdgen . Yeah it was ugly but it worked... it might hold you over until you can get to a junkyard. We used a t-connector that was meant for heater hoses, and since the line to the pcv valve was smaller, we wound up using the same size hose all around, and then wrapping the pcv valve with electrical tape. We really wanted the car to start that night, and the parts stores were already closed!
Looking back... if we had access to parts, it would've been nice to have used the same size hose all around- but instead of electrical tape, I bet we could've found a large-to-small tubing adapter, and screwed one end into the "large hose". Then we could've hooked the adaptor's small end up to a small hose that would fit the PCV.
Old Jan 28, 2004 | 11:36 AM
Slow2.8's Avatar
ya i was about to rig it up like that, one more place to check first for the part... its a chevy dealer so im going to see if they can specially order it. if not, i'll be using heater hoses also
Old Jan 28, 2004 | 02:21 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
YOU ARE LOOKING FOR THE PART THAT IS LIKE A ODD SHAPED T
wITH 3 HOSES THAT GO TO IT. I BROKE MINE IT WAS LIKE 5 BUCKS AT THE DEALER. AND THE HARD PLASTIC HOSE IS NOT MADE ANY MORE GM REALISED IT WAS CRAP AND WENT BACK TO GOOD OL RUBBER HOSES.
Old Jan 28, 2004 | 04:16 PM
Slow2.8's Avatar
thats exactly what im looking for, do you happen to remeber the name of it or the part number?
Old Jan 28, 2004 | 04:40 PM
FAST RS's Avatar
I DONT REMEBER WHAT IT WAS CALLED. I BROUGHT THAT PART IN AND THEY KNEW EXACTLY WAHT IT WAS. I THINK YOU MIGHT EVEN BE ABLE TO FIND IT AT AUTOZONE BY THERE PLASTIC T CONNECTORS OR IN THE HELP SECTION. I SUPERGLUED MINE TOGHETER UNTIL I WAS ABLE TO GET A NEW ONE.
Old Jan 28, 2004 | 04:49 PM
Slow2.8's Avatar
thanks for the help, i'll bring it down to chevrolet tommorow and try to get it. did yours have a small hose going to it also? i know that theres a hose going from the throttle body to it, and a hose from the valve cover going to it, but im not sure about this other small hose, its' small like the one emissions uses and its on the right side of the plenum... just wondering if yours was setup like that cuz im trying to find out what that small hose is for
Old Jan 28, 2004 | 05:03 PM
FAST RS's Avatar
I DONT REMEBER ONE GOING FROM THE VALVE COVER TO IT I REMEBER ONE PART GOES TO THE tb THE OTHER HOSE HAS TO DO WITH MY CRUSE CONTROL ILL HAVE TO LOOK AT THE OTHER HOSE WHEN I GET A CHANCE THIS WEEKEND WHEN I DO AN OIL CHANGE.
Old Jan 28, 2004 | 05:53 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
if it's the hard plastic line that goes under the intake plenumn then i know what you're talking about too.. i don't remember the piece being 5 bux, as it was pretty long, i kept my old one, but when the guys were replacing the engine they broke the one that was on there...so i picked a new one up from the dealership, think it was 30 bux max...but closer to eh, the lower end of prices.
Old Jan 28, 2004 | 05:56 PM
FAST RS's Avatar
WHAT IM TALKING ABOUT IS A ODD SHAPPED IT HOOKED UP TO THE BACK OF THE PENELUM IN THE MIDDLE I THINK HE MEANS THE TOP PART I WILL TAKE A PIC LATER TONGIHT IF I CAN GET MY HOOD OPEN. IM TRYING TO AVOID OPEING IT BECAUSE THE HOOD CABLE IS ABOUT THE BRAKE.
Old Jan 28, 2004 | 07:19 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
here does this help?
Old Jan 29, 2004 | 08:08 PM
Slow2.8's Avatar
the part from gm is not servicable so im going to have to use heater hoses and a 't' to connect them... thing is the small hose that leads to the cannister is broken so im not going to be able to hook that up, what im wondering is what will be the negative effects when the car is on? since i wont be hooking up that line??
Old Jan 29, 2004 | 10:08 PM
FAST RS's Avatar
i will take a pic of the part tommorw wheni tae pics of my car. Now i am wondering how it works.
Old Jan 30, 2004 | 10:43 AM
br()bert's Avatar
Car: 85 firebird
my car ONLy has these lines in red, no can or lines to the egr thingy, runs fine. As long as you dont leave any vac lines open to leak.
Old Jan 30, 2004 | 11:20 PM
FAST RS's Avatar
is this the part?
Old Jan 31, 2004 | 12:30 PM
Slow2.8's Avatar
no thats not it... look at the hose that goes from the right valve cover into the back, that hard plastic back there is the piece i broke, i managed to make a whole new system out of heater hose, and using a copper pipe "t" as a connecter. it runs fine without the little hose hooked up. still need to clamp down a hose but other than that i've rigged it up pretty good.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
NZKnight
Oct 15, 2015 02:47 PM
2012sergen11
Oct 13, 2015 07:38 PM
sleprock
Sep 24, 2015 04:33 PM
