How do I know how many amp alternator I have?
Old Feb 2, 2004 | 06:49 PM
bes217's Avatar
I need a new alternator but there is like 3 different amps. 74, 94, 108 amp. Which one do I have and how do I tell? I need help fast please. Should I just get 108 amps because it can make the most or what?
The reason that I think I need a new alternator is because I am getting voltage spikes. My engine will be at like 14.3 volts and then drop to 0 then like 2 and down again and then up to 14 then back down to 5. All over the place. Could it be just the voltage regulator? Please help.
Old Feb 2, 2004 | 11:16 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
:lala:
Old Feb 2, 2004 | 11:27 PM
bes217's Avatar
You know what I meant. Don't get smart with me!!
Old Feb 2, 2004 | 11:28 PM
bes217's Avatar
But seriously what amperage alternator do I need or how do I tell what I have, or do you guys think it is the alternator or just the voltage reg. or what?
Old Feb 2, 2004 | 11:33 PM
br()bert's Avatar
Car: 85 firebird
Mine is stamped on the alt itself. i only have a 84 amp alt. Sorry i cant help with the other questions.If you replace it i'd get the most powerful alt i could
Old Feb 2, 2004 | 11:38 PM
bes217's Avatar
So it really wont make a difference how many amp alternator I get?
Old Feb 6, 2004 | 10:09 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Check your RPO codesin the RPO decoder. The only ones I remember off hand are:
K60 = 100 amp
K68= 105 amp
Old Feb 7, 2004 | 12:09 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I just bought a 160 amp one. Only a hundred dollars on ebay! Lifetime warranty as well! My factory one is rated at 105.
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
