V6 Problems
Old Feb 2, 2004 | 08:38 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
V6 Problems
Ok guys i have a 92 RS with the 3.1L and a T5. I have 4 problems with the car.
1. It heats up then once i drive the temp drops right away and sometimes it wont heat up unless i let it sit for 20 minutes or more, i tried a new thermestat and i have an adjustable thermestat on my fan so i turned the fan off- i have no heat and its freezing in NJ at night
2. Im stalling out- when i push in the clutch it revs up to 3500RPM untill i come to a dead stop then somtimes maybe 1/10 stops itll stall. I have a new TPS sensor, maybe IAC?
3. I Idle at 1700RPM, i pushed the throttle set screw all the way back and set the TPS sensor to the lowest it will go- what else? thanks guys.
4. About once a month i go to start the car- it wont start, i get the lights when i turn the key but it doesnt even try to kick the starter- i thought it was the silanoid getting stuck but I bought 2 new starters and it still does the same thing, is there a relay somewhere. If anyone can shed some light id apreciate it thanks.
Old Feb 2, 2004 | 10:14 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Hmmmm.....
2 and 3 sound like it could be an intake leak. Test for one by allowing the car to idle when cold and spraying starting fluid all around the intake and vaccumn areas, if the rpm jumps or somthing pops, its got a leak. as for the heat...I dunno, mine has the same problem....But I live in Texas too sooo......
Old Feb 2, 2004 | 10:48 PM
AJT86's Avatar
thanks man, i tried that befor and got a little jump- i tightend as much as i could but it wouldnt go anymore- ill try a new gasket
Old Feb 2, 2004 | 11:18 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
How are your vac lines? Check for leaks EVERYWHERE in the vacuum system. As for the heating problem, maybe you should have your core backflushed to remove crud from the system. If that don't work, swap in a new heater control valve. Check the heater controls to see if they have adequate vacuum or if they leak.
For the last problem, Trickster may be able to help. It sounds like that is possibly caused by the VATS system.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
