HELP PLEASE.... Where is it....
Old Feb 9, 2004 | 10:51 AM
mota420's Avatar
I need to find the bolt that loosens up my distribuator cap so that I can time my 2.8 V6. Can any one help?
Old Feb 9, 2004 | 11:53 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
to the pass side of the car, and rear just a hair from the base of the distrib.
Will be 15mm. Its a pita to get too.
Old Feb 9, 2004 | 12:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It down there somewhere under the cap, hard to see, hard to find, hard to get something on it, just hard hard hard.
Get your hands down there some how and feel for it. Its next to the shaft. Just feel down the shaft and around the bottom of it for the bolt.
There is a Viagra joke in there somewhere too.
Old Feb 9, 2004 | 02:45 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
when you find it you'll need a 15 mm socket lik edale said, a swivel, a 2-4 inch ext, and i found a dist wrench on the end of the ext the easiest way to loosen/tighten the bolt. I left mine tight enough so the dist wont turn from the engine rpms but loose enough so i can turn it with two hands. Its not fun to get to.
Old Feb 9, 2004 | 08:33 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I bought a wrench
They make the 15 mm distributor wrench for theese motors. Problem is, the only place you can get it is through a tool company (snap-on, Cornwell, Matco, MAC etc.) Mine cost me like 18 bux or something, works great. A very good investment, believe me. Funny that they only used the design on 3 differennt models too (S-10, F-body, Cadillac)
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
mcconahay37
Oct 15, 2003 02:17 AM
sunbound
Sep 14, 2001 02:38 PM
RED92
Aug 31, 2001 01:44 PM
porcupine
Aug 23, 2001 11:58 AM
