Knock sensor Retrofits
Old Feb 15, 2004 | 03:26 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
have any of you retrofitted a knock sensor on your motor before? I want to set up my new motor with one for a little insurance. Any details would be appreciated, thanx.
Old Feb 15, 2004 | 03:51 PM
bes217's Avatar
I think Dale was doing something with an LT4 knock sensor so you may try sending him a PM.
Old Feb 15, 2004 | 06:18 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
A 1986 2.8mpfi should already have one on the pass side of the engine right around the starter.
I am planning on attempting an install of a 1996 LT4 knock sensor which is supposibly one of the best sensors GM made in that it doesnt recognize as much, eleminating "false readings".
Money has limited this so far.
Their is also a resistor/wiring trick you can do for less money if you dont mind hacking a harness.
Old Feb 15, 2004 | 06:33 PM
FbodTrek's Avatar
That's an odd thing..
Thing is, the 2.8 did have a Knock sensor, problem is, it wasn't hooked up. There wasn't even a connector for it anywhere on the harness . the sensor was also inserted into the water jacket hole (makeshift plug?). I also nned to find a good place to put the coolant sensor so I can eliminate that darn code.
Old Feb 15, 2004 | 07:22 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
my 2.8 doesn;t have one. I don't think they were installed until the 3.1 came out
Old Feb 15, 2004 | 08:01 PM
Dale's Avatar
Engine: 350 S-TPI
my camaro repair book list them on the 2.8. It is a blue wire.
Yes, on my 2.8 in the s10, I had to replace it and when I pulled it out, coolent came out also.
Old Feb 16, 2004 | 12:45 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
by golly, you're right, but that still doesn't solve the problem of why it isn't on my actual car. All I have is the Coolant Temp Sensor(grn wire) but no blue. Kinda strange, huh? I even pulled my computer and don't have a blue wire in the harness.
Old Feb 16, 2004 | 06:20 AM
Dale's Avatar
Engine: 350 S-TPI
then I have no clue. I just know what my book(s) say. As for it not being on the engine, it could have went bad, or the plug broke and someone said "hey it runs fine w/o it" and hacked it.
But that doesnt explain why its not in the ecm wireharness.
Old Feb 16, 2004 | 06:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There shouldn't be one! I've never seen one on my car, or on the 2.8 I helped my friend swap in his '89 Camaro 2.8. You sure this wasn't an 82-84 carburated thing? Or was it a California emissions piece for the 2.8's?
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
