Now it's even harder to start....grrr
Old Feb 18, 2004 | 10:47 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Replaced the MAF sensor and the fuel pump relay and now when the car is cold, it takes even longer to fire up. This is really getting stupid. How do you check the TPS and IAC to see if they are operating? I'm going to try to set them tomorrow and re-check timing. So far I've replaced fuel filter, fuel pump relay, CTS, MAF sensor, plugs, wires look ok. And, I notice that the fuel pump is not continuing to run after I shut the car off.
Old Feb 18, 2004 | 11:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Now it's even harder to start....grrr
At least you have some good news out of this. The pump isn't supposed to run after the car shuts off.
Old Feb 18, 2004 | 11:19 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
It sounds like you need to check the fuel pressure. If your fuel system doesn't hold the pressure like its suppose to, it will make for a very hard start. Possible problems for the fuel pressure dropping is a bad regulator or a bad check valve in the fuel pump.
Old Feb 19, 2004 | 08:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i had that problem, it was my injectors leaking down. when i swapped out the 2.8 for the 3.4, problem solved. make sure its not your injectors, do you notice it running rich at all?
Old Feb 19, 2004 | 04:22 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
CSI?
Old Feb 19, 2004 | 04:24 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Re: Re: Now it's even harder to start....grrr
Actually, it is.. it's a sign of good oil pressure holding the switch closed, even without the pump spinning.
EDIT, I'm not proclaiming this was a brilliant move by GM engineers, nor am I sure it applies to all year vehicles, but mine and a number of other v6s I know of all do this
Old Feb 19, 2004 | 10:00 PM
sixbanger's Avatar
I forgot to mention, I also replaced the FPR. The pump only runs sometimes, not every time I turn off the car. I think I'm going to try the Motorvac and see what happens.
Orr89RocZ
Feb 13, 2016 10:04 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
mfp189
Sep 27, 2015 09:25 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
