Stupid question about tach
Old Feb 29, 2004 | 11:22 AM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
How do you hook up an external tach. Where on the distributor does the one of the wires hook up? It is a portable hand held tach thingy. I want to set my IAC but car doesn't have tach.
Old Feb 29, 2004 | 10:08 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I don't remember ff hand how the 6A was hooked up, but either a) try a search
&/or
b) check out MSD's web site on hook up diagrams, they list the tach wire in those I belive.
Old Mar 1, 2004 | 11:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Coulda just done a search, I've posted this many times.
You want the black/white wire, from the gray coil connector.
For more info, see here: https://www.thirdgen.org/techbb2/sho...hreadid=193133
Old Mar 1, 2004 | 07:34 PM
sixbanger's Avatar
I don't want to mount it permanently. I just want to be able to attach it under the hood while I work on the car. It's one of those "EL cheapo" hand held tach/dwell tester units. So splicing is not a real good option. I have a regular gm hei unit on my truck that I can just plug one the the tach wires into. It clips in and out nice and easy. Does the firebird have this ability?
Old Mar 2, 2004 | 09:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ah; gotchya. "Supposedly" the later model 2.8 and 3.1's had an extra wire piggybagged onto the black/white wire I mentioned. The wire ended in an insulated terminal and was tucked along the wire loom; that's where the diagnostic tach would go.
Even my '86 GM book shows that wire; but my '86 2.8 doesn't have it... and I've never seen it on any junkyard car, either. So you could splice a short 2 inch length wire into the black/white wire, add a terminal to it, and cover it up good. Check along your ignition coil's wiring loom; maybe you'll get lucky and it'll be hiding there.
Old Mar 4, 2004 | 08:29 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
OR.......you could kill 2 birds w/ 1 stone and buy a timing light that has a digital tach readout.
LOL, I just look for excuses to buy new tools......
Cleotiz
Jan 6, 2018 08:56 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
stalkier
Aug 7, 2015 04:49 AM
