Swap out 2.8L 6, swap in 2.8L 4
Old Mar 3, 2004 | 10:10 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Have you guys seen the new GMC Canyon engine? I-4, 2.8L, 175hp @ 5600 RPM, and 185 lb-ft torque @ 2800 RPM. Can't wait till somebody cracks up a new Canyon so I can put this baby in.
Old Mar 3, 2004 | 10:13 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
good luck, that probably won't be an easy swap at all. anything is possible though.
Old Mar 4, 2004 | 12:56 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I thought the Canyons have I5 motors.
Old Mar 4, 2004 | 02:06 PM
There's an I-4 and an I-5. I believe the I-4 option is new.
Old Mar 4, 2004 | 07:14 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Would u really want to drop in a 4banger of a 3.4 with similar numbers, what aobut doing the 3.4 $350-550, then some intake and head work with cam $750-1400, with the head work i can see 230HP easy on the 3.4, then this way there was no hassle with making something fit, jsut replaced and made more efficent
Old Mar 4, 2004 | 08:06 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
seems like a lot of extra work, for some minimal gains to me...Ls1 swap (lots of work, lots of power) .... 3.4 swap ( not much work, good power gain) , 3.8swap (lots of work, good power gain), Northstar swap (tons of work lots of power) factory set 4 cylinder setup, (american 4 cylinder too) lots and lots of work, minor power gain, in the end you'd probably end up happier moving to a 305. just a .02 opinion though.
Old Mar 4, 2004 | 08:27 PM
Car: 87 Firebird
Engine: 5.3 76mm
Dont know if u know it, but if u do the work to get a 305 in there, dont stop, 350 is the exact same on the outside, drop in the extra 75HP with the 350, all if u were to go that route, plus there is alot of help around here to help with a v-8 swap over the I4
Old Mar 4, 2004 | 10:18 PM
Wow! I can't believe people took that seriously! I'm not really considering putting an I-4 in. But on the other hand it would be kind of cool. It has a lot of similarities to the original 2.8L V6 though... I don't know how much it weights (it has to be at least as much as the 'maro), but it comes from a RWD GM vehicle, and I'm sure there is a manual tranny that bolts to it. Anyways, I'm not even considering a swap any time soon. In fact a custom supercharger is on the list higher than a swap. But it's interesting to know everyone's opinions nevertheless.
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
BurlyChev
Aug 16, 2015 09:08 PM
gwade12
Aug 8, 2015 08:17 AM
