heater contol valve???
Old Feb 29, 2004 | 11:22 PM
ionicswing's Avatar
last winter, i had great heat, now i have no heat, hopeing its not the heater core(too lazy to take dash off), does anybody know where the heater control valve is located, or would that be the source of my prob, and blower still works great.
Old Feb 29, 2004 | 11:45 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
the control valve is on the passenger side of the motor right next to the fender. The coolant line that comes out of the front of the motor and has the off shoots for the TB coolant passage goes right into it. It is a black plastic thing with 3 heater/coolant lines connected to it and a vacuum line connected to the top.
Old Mar 1, 2004 | 12:04 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think mine's a slightly different setup w/the vslve under the dash, controlling the flap to let air thru the heater core as the hoses go directly into it.
Old Mar 1, 2004 | 05:51 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
my heat wont work unless I tug on the bottom vac line on the control module. Some how it leaks not creating a good suction.
Old Mar 1, 2004 | 11:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yank that dumb composite heater valve out and bypass it- before it cracks on you. I've seen that happen too many times; I'm glad my car doesn't have one. (That heater control valve started in 1987)
Bubbajones_ya
Jul 6, 2024 08:32 PM
drptop70ss
Oct 4, 2015 09:44 PM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
