v6 + v8 parts interchangeable?
Old Mar 7, 2004 | 04:39 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
hey guys, well i have a 88 v6 camaro and i have a buddy with a 89 gta, he converted his car to carb a while back and has a lot of spare parts he wants to throw into my car, so heres the question whats interchangeable? maf, distributor relay (or whatever its called) and a bunch of other stuff?
any input would be appreciated
Old Mar 7, 2004 | 04:52 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Pretty much nothing engine-related... MAFs are completely different (frequency film digital MAF vs hot-wire analog MAF), I'm going to assume you mean ignition module as far as "distributor relay", and that might swap over, however there's no performance gain to be had.. probably the same exact part.
Swapping the 7165 ECU he has into your car, however, would open up the use of the analog hot-wire MAF, however you'd need a very custom chip to make the swap work.
Post a complete list of what he has.. we'll let you know.. however, don't be surprised if there's relatively little you can use in stock form.
Old Mar 7, 2004 | 06:15 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
alright, thats pretty much what i figured i'll get a list off my friend tonight and post it
Old Mar 8, 2004 | 10:14 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
I doubt anything will be of use to you as far as engine parts go. The only V6 I know of that has any interchangeability with the V8's is the 4.3 (and that's limited)....your engine is considerably different. Brakes, suspension, and body parts are the only items that are really interchangeable between V6 and V8 thirdgens, as far as I've seen...
Old Mar 9, 2004 | 01:01 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
figured'd it wouldn't hurt to ask
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
