Easy way to find a vacuum leak?
Old Mar 7, 2004 | 06:32 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys i'm still stuck with my starting problem, and i'm trying to see if a vacuum leak. anyone know of any easy or surefire ways of finding a vacuum leak?
Old Mar 7, 2004 | 06:52 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Brake cleaner
Or starting fluid. Spray around the intake and plenum, if the rpm spikes (do with engine running), you have a leak.
Old Mar 7, 2004 | 06:54 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thanks
Old Mar 7, 2004 | 07:04 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Propane
Old Mar 7, 2004 | 07:40 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Originally posted by Damien00677
Propane
as good of an idea as that is, i think i'll pass
Old Mar 7, 2004 | 09:04 PM
As always, thats your option. I just like it better than spraying all kinds of fluid onto my engine.
Old Mar 8, 2004 | 04:24 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
although it could work quite well
Old Mar 8, 2004 | 04:57 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Easy way to find a vacuum leak?
You said that you are having a starting problem, does that mean that you have a no-start condition or that you have a hard-start condition. If you can get the car running, just shoot some brakleen around all the gasket surfaces and vacuum lines, if you have no-start at all, hook up a guage and see what you get for cranking vacuum at the port on the back of the plenum where the brake booster and accessory vacuum lines are. just pull the little one and hook up a vacuum guage to it, crank it, and record readings, depending on what kind of vacuum you get, you'll see if you have a leak or not.
Old Mar 9, 2004 | 01:03 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ah my car runs alright , its just a hard start and it idles higher then it used to.
when i first bought the car it started first crank no problem, idle was at 750 , one day i pulled a plug to check it, put everything back on and now it idles between 1250 and 1500 and its a rough idle
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
