Weight on the back of a T5?
Old Mar 11, 2004 | 08:15 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Why is there a big weight on the rear of my T5 tranny? Does anyone else have one? Is it necessary? Why is it there?
Old Mar 11, 2004 | 10:02 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
helps on vibration. This idea was mainly used on the astro vans.
Old Mar 11, 2004 | 07:54 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I have one of those things. I assumed it provided some sort of protection from foreign flying objects, but the vibration story sounds better.
Old Mar 11, 2004 | 07:58 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Hmmmm, my '86 Firebird was originally a 2.8 V6 in front of the 5-speed and I don't have the weight. Makes me wonder which cars got them...
Old Mar 12, 2004 | 01:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It helps in vibration as the tranny is rubber mounted and will want to kind of bounce as torque is applies. That weight helps keep it in place. i had two of them at one and ended up giving one to a friend to use on his ford truck, it help do the same thing. Kept the shaft of the tranny from bouncing with torque.
Old Mar 12, 2004 | 02:23 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
So would the purpose of the counterweight be negated by an ES poly trans mount? Love to ditch that extra weight. Almost make up for the turbo
Old Mar 12, 2004 | 07:37 AM
Axle/Gears: 4.10
Hmmm.....good question techsmurf. I figured I would probably leave it there even though it may not be completely necessary. At least that extra weight is close to the center of the car.
Old Mar 12, 2004 | 12:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well you could just solid mount the tranny. but then the torque arm is useless.
For the torque arm to work the whole system must be able to move around.
Later on my friend did end up mounting his two trannys down solid. The weight helped but once he had two trannies end to end they had to be mounted solid.
[Yea he had two 4 speeds end to end, talk about gear ratio's]
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
crazynights
Aug 21, 2015 06:53 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
