anti freeze pissing out of engine
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys i went to head to my gf's, i stopped to pick up gas, filled up, went to pay, and saw a bunch of anti freeze leaking from my car. i quickly popped the hood and saw it coming from the oil pan area (underneath of engine).
i haven't had a chance to look at it yet as its very dark and i have no ramps. anyone have any ideas on what it could be so i can stop worrying (or start)
If it is freeze plugs, I think you may have to pull the tranny,
not to certain I've never done it.
Do a search on this board for "freeze plugs"and see what comes up.I had antifreeze leaking in the same spot and it turned out to be leaky intake.Good luck.DUECE
Car: 1998 Camaro Z28
Engine: 6.0L
where under the engine? front, back, left, right? if its the front, it could be the waterpump or front cover gasket leaking. sides are probably the freeze plugs. get a light and see if you can tell at all. freeze plugs can be a PITA to replace if you dont have a good angle on them.
theshackle
Mar 5, 2017 06:37 PM
Sanjay
Aug 12, 2015 03:41 PM
