Mpg
Car: 92 RS 25th Anniversary
Engine: 3.1
320!!
i only saw above 300 when i was going to addison everyday for a week otherwise im empty at 230
whats done to your car? besides a 5-speed i know they get better gas mileage then autos anyways...
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Mine if I'm treating her well gets about 24 mpg on chevron premium. on the other $hit gets like maybe 20 mpg.
But the likly hood of me driving considrable, I do, do it. but not very often. So I usually get about 20 mpg. I say whatevers
Car: a car being parted out
Engine: blown up
Transmission: in peices
For one, I keep a check on the timing almost weekly.
Another I check the plugs every 2-3 weeks.
I keep an eye on my tire pressures.
Lastly I don't use the ****ty gas that you probly do. Only BP 92 goes into my tank.
The QUALITY matters more then the 'Octane" level. Do not ecepct to get anything when the gas you use costs 1.50... I burn through that in under 200...
You can call whatever you want. I will take a pic next time of the ODO and the gas amount I put it if you want.
Full list of ignition/Fuel...
AC Delco... .050 gap.
CrapZone $26 wires.
Factory coil
Replaced factory/delco ignition modulator.
19 Lb TPI injectors.(cleaned by cruzinperformance)
12 Mo Old fuel filter.
factory fuel pump.
9 Mo Old O2 sensor.
I also unplugged the EGR, I thought it would have hurt the MPG, but it made no noticible difference.
No air pump.
High flow Cat(but I DO NOT SUGGEST THEM) I personally hate mine.
2.5" Dyno cat back.
I have actually gotten 356.8, but it ran dry... and that sucked as the low gas light does not work, and I do not feel like dropping the tank to fix it.
CrapZone $26 wires.
Factory coil
factory fuel pump.
9 Mo Old O2 sensor.
No air pump.
2.5" Dyno cat back.
Engine: 3.1
i dont get 93 cuz when i do it only gets me an extra 30 miles of the full tank so i say save the .35$ a gallon and go with 87octane
my friends 91 ws6 gets 240 outa the tank and thats when he hotrods it
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Im getting 12-14 city no matter how i drive, and 18-22 atbest on the freeway @60. I think i just need a new car
Maybe a '00 with an LS1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I would like to see the proof of your mileage too, cause I have a hard time believing it. I'm not saying that i'll believe you once I see, there are ways of manipulation, but i'll be more willing to believe you.
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A stick is a tad better on gas as you can get into 5th by 35 easy without bogging it but I think the downshift is the biggest gas hog on a stick.
Sounds neat and you stop much better down shifting but I seam to get much better mileage when I'm not down shifting every gear at a stop.
Car: 95 Mustang GT Vert
Engine: 5.0
Doward here.... 320 per tank's not unreal... I do 300 each time i fill up, and i'm putting about 12 gal back into it. 320 I could do, but don't like it when I take a turn quick, and she dies
The furthest I've gone yet, was 346 miles, but I rolled into the gas station on fumes!
I think it was like 15.3 gal to fill her back up!
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I usually fill up at 200 cause I know my gas guage lies.
I use to get about 17'ish in town. I have pulled 20-21 in town.
On the one road trip it has been on, it got between 23-28.
New engine, I have yet to work out the bugs, so no-telling. I know when my o2 meter is pegged rich, and throwing rich code, its not doing to well
Car: 87 Firebird
Engine: 5.3 76mm
I have alot of trouble getting 150 per tank, thats 13gal for me to fill back up. I think i got something way out of tune.
And LS1 F-bodys get around 18city and 24Highway according to sticker in the window at the dealership
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep just about an V8 gets better than 11-12
You must be leaking. Car would really run bad if it used that much fuel. i think?
Car: 91 Firebird
Engine: 191ci 6cyl
I get about 270 miles to the tank. That's with high flow cat, flowmaster exhaust, K&N air filter with the stupid container removed that comes stock with a 91 v6. Auto tranny and I do 60miles each way to work. Wondering if there is anyway to increase my mpg?
Engine: blown up
Have the injectors cleaned.
Do a complete tune up(if not already done)
Take the excess stuff from the car.
Engine: 350 S-TPI
Originally posted by FirebirdNYC
would an emission test show excess burning of gas?
Car: 1990 firebird
Engine: 3.1 v6
hm im getting ****ty mileage, and i passed my inspection with flying colors. if it does show excess fuel burnage then what can my ****ty mileage be? can new york city driving in a fbody kill that much gas,
ps, i took her on the highway today and all of the sudden my servince engine light went on. shut the car off for a few and it turned off
Car: 87 Firebird
Engine: 5.3 76mm
When u restart the car u wont have the light come right back on, it will only come on when ur car has enough time to register if something is amiss, flush out the code and see what it was, my bet is 32,33,34,44,or45 i have gotten all these codes only when driving for a long period of time, and i seem to only get 13mpg
U can find the pins to cross to flush out the codes, any Qs Message me and ill forward the tech to get the codes and how to read them and what they mean...
Car: 91 Firebird
Engine: 191ci 6cyl
I just started getting a code 32 in my car and I only get it when I get off the highway at my work which is a good distance away. I'm getting roughly 18mpg right now which is mostly highway driving...
As far as cleaning my injectors goes, would I have to take the top of the motor apart and take them out and clean them or would using injector cleaner suffice and if so which would be the best to use?
Car: 91 Firebird
Engine: 191ci 6cyl
I got some stp injector cleaner, drove a full tank of gas got 277mp tank on premium then filled on premium again and put the stp crap in and just did 325mp tank. I've also had the egr go dead on me in that time so I don't know if that helps or hurts, that's also with having to do 90mph to work today cause I was running late.
Car: 89 f-bird and some others
Engine: 3.4
used to be 300-310
took car to germany, went down to 240-250
made modifications, went up to 270-280
got back here, went to 300, rebuilt distributer again. used some injector cleaner, got 320 the other day with room to spare. will try again and see if i get the same.
i need to take care of that exhause manifold leak and see what happens
Yeah, I don't know why people keep thinking the V6 fbodys get better gas mileage. They don't
The only advantage to a V6 thirdgen is insurance and that is only sometimes.
Engine: blown up
The 3rd gen V6's DO get better Mileage then 3rd gen V8's.
My old TBI 90 got 270 if I was lucky.
A 88 TPI got 290.
My 92 V6 gets 320 religously with 1/8 tank left.
Compare same gen cars, we know that the LS1's get upwards of 280+ depending on how they are driven. But you also go through many more sets of tires.
No, its not joking. My 305 TBI car got about 20mpg. My 89RS v6 gets about 12mpg. (it needs help I know). The 92 Firebird v6 with 70k miles on it got about 18mpg.
Maybe your v8's just needed a tuneup or something.
Car: 1986 Firebird
Engine: 2.8 V6
I've always gotten crappy mileage; unless I'm heading out on a long inter-state trip, where it's a constant 65-70 mph. Around town, forget it- my mileage is bad. It's just a smaller engine trying to push a heavy car...
Engine: blown up
As stated above, My V6 was al teast 30-40 miles more per tank then my V8's ever did.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If a V6 used more gas than a V8 wouldn't that be one poor running V6 and very obvious????
5.7
2.8
300 miles
15 gal gas
the 2.8 should used less, at WOT for 300 or 35mph.
5.7
2.8
300 miles
15 gal gas
Remember the 2.8 was way too small for the thirdgen. A 3800 or something would be a different story. I think the whole V6 thing was to appease the EPA and insurance companies. I haven't ever noticed a real difference in gas mileage between the V8 and V6 cars.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
