Car won't start. Need a little help please
Old Mar 15, 2004 | 12:48 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Ok. The car was down the most of the winter I had some major timing problems I was able to run it in park for a half hr a week so it didn't just sit and rot away. Well I finally got the timing problem fixed and put a new Accel super coil in and it ran a lot better (still sputtered here and there). Well I've been using my mother-in-laws car all winter, so she had her car today so I had no choice but to use the Camaro well I put it into reverse and started backing down the driveway and when I went to turn, the car just shut off. I tried to start it and it sounds like when a carburetor is flooded. It tried then just stumbled and off again it would only try for about 3 sec and the it would just turn and turn with nothing. Have you ever tried to start your car with the air tube for the TB is off at the TB, it also sounds like that. Any Ideas are welcome. The car is a 1987 Chevy Camaro Sport coupe LT it has a 3.4 MPFI
Old Mar 15, 2004 | 01:00 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
You got fuel?
With the key on and the fuel test port pressed, do you get any fuel?
Old Mar 15, 2004 | 01:19 AM
I am getting fuel I can smell it. The fuel pump kicks in and sounds normal. I changed the filter right before fall. I have only put maybe about 1500 miles on it since then.
Old Mar 15, 2004 | 03:20 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Try this. I'm not sure if you have a 7th injector (cold start) I know for a fact 2.8s do. They tend to stick and they will just flood the crap out of the car. Pull the plugs, they are probably crapp. Make sure you have spark going to ur dist. then to ur plugs. Let me know
Old Mar 15, 2004 | 10:35 PM
I do have the cold start fuel injector (7th injector)
Old Mar 15, 2004 | 10:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
would just unplugging CSI work?
wouldn't it be sticking mechanically and not electrically???
If it is sticking it should just throw a code and still leak???
Old Mar 15, 2004 | 11:04 PM
Well I can go try unplugging the CSI the car is stuck at the end of the driveway (Damn that thing is one heavy ****).
Old Mar 15, 2004 | 11:24 PM
Nope didn't work.. I had no responce at all it didn't even try to start just turned..
Old Mar 15, 2004 | 11:52 PM
I took my plugs and wires and coil out. Five of the spark plugs were fine and smelled like gas...not that much wear. But the sixth (piston cylinder # 5) was soaked with oil. I can't tell if it was top or bottom. It was completely soaked, caked all over it. So it's either bad valve seal or piston ring. Could this be causing my problem?
Old Mar 16, 2004 | 11:26 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
The oil fouled plug won't help, probably a valve guide.. but the other five are gas fouled now too. Replace 'em all, you'll probably have much better luck getting her to fire. Don't buy expensive plugs, either, because there's still a chance the next set will end up fouled too.
Old Mar 17, 2004 | 12:01 AM
Well I just cleaned all the plugs. They are like new now. I found a few plug wires that had holes in them and wore away in spots to the wire and one of them were on my coil wire. Well I found some spares I had in my garage that were used but in better condition. So (weather depending) I'll go out and put them back in the car and see what happens....
Does anyone know where I can get the bracket that holds my Coil and part of the EGR system. Mine kinda got broken when I did the engine swap and its only held on by one bolt and it keeps comming loose.
Old Mar 17, 2004 | 12:58 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Just a warning, so you're not too let down if it doesn't fire up... I spent about an hour cleaning my fuel-fouled plugs and FILING the electrode to make sure it was 100% perfect... still didn't start.. but it fired up in about .0325 seconds with new plugs.
Coil/EGR bracket would be a junkyard part.
Hopefully the wires were the main problem
Old Mar 17, 2004 | 02:46 AM
All of the Junkyards around me don't have that bracket I need.. Well they mostly crushed all of the V6 Camaro and firebirds. GM discontiniued that bracket they can't even get it.
Old Mar 19, 2004 | 04:38 PM
Well... I put the plugs and different wires in and now it starts but it goes chug.......chug.......chug....... The moment you give it gas it dies.
Old Mar 26, 2004 | 09:05 AM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
What all did you do when you adjusted the timing? Was it a bad/sloppy chain? Or did you just mess with the distributor? Sounds to me like the timing is still off a bit.
Is your EGR good? Could be clogged up with junk.
How about the ign. ctl. module. was that changed?
Without it in front of me, I'm just throwing out options and prior experiences here.
Old Mar 26, 2004 | 09:46 AM
Well I can now get it started but thats about it. I just gave it a fresh tune up. And got a Accel Super Coil. It takes for ever to rev up abd when I give it to much gas it dies and when I put it in gear it dies. I have a bad donut gasket. The EGR isn't hooked up it never has been and the car ran ok with out it. It was making a horible scretching sound like my fuel rail was loose well I fiexed that and it still doesn't work. I have a quiet knock coming from the enigne (sounds like its in the Passenger side head). It has a new Timing chain. I have gone over the car time and time again trying to figure something out. When I set the timing I unhook the EST wire put the engine at TDC and set the cam with what my Haynes manual says. And just turn it from there. And it Idles really low.
Old Mar 28, 2004 | 04:43 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
get your ECM checked.
take a look
here:https://www.thirdgen.org/techbb2/sho...hreadid=226133
Horst
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
86Base
Aug 8, 2015 01:34 PM
