fuel filter questions need fast answer
Old Mar 24, 2004 | 04:15 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
How do i depressureized the system, and do i need to put pipe dope on the threads
Old Mar 24, 2004 | 04:20 PM
LUVmy92's Avatar
Car: Camaro
Pull the fuse for the feul pump and start it, car will run for a bit and just let it die then restart till it wont anymore! Worked for me but feul stil leaked on me but no pressure. I did not put anything on the threads and it doesnt leak, been a few months since i did it.
Old Mar 24, 2004 | 04:30 PM
Transmission: autos
i cant find a fuel pump fuse, onlyu inj 1 inj 2?
Old Mar 24, 2004 | 11:53 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
i'd bleed the pressure at the fuel pressure test valve, and remove the gas cap. or i think you can just wait a couple hours and the pressure will drop on it's own.
Old Mar 25, 2004 | 01:04 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
According to the GM manual I have for my 88 Camaro it says to pull the inj1 and inj2 fuses which will cut off power to the injectors. Then try to start the car and of course it will not run. Then try it once again for about 3 seconds. When removing the filter it will leak but it will not spray as it would if pressurized. And be prepared for a lot of gas fumes, it gets lovely if you don't get some fresh air so keep the air circulating.
Old Mar 25, 2004 | 11:44 AM
Transmission: autos
i pulled the inj 1 and inj 2 fuses and it wouldnt start but did not depressureize, i undid the gas cap and that took care of most of the pressure.
Old Mar 25, 2004 | 12:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You don't need any teflon tape for the threads. When you remove the old filter, inspect the ends of the fuel lines. There should be a small o-ring at the extreme ends of the tubes. Sometimes an o-ring can stick inside a fuel filter and come off the tube! As long as those o-rings are there, you won't get any leaks.
I've never depressurized my system; just wear goggles and do the work outside. I also put my arm thru a garbage bag so I don't get any gasoline burns. Avoid dropping a wrench onto the concrete; it can cause a spark (and explosion)!
Old Mar 25, 2004 | 05:10 PM
JoshDT91's Avatar
Engine: 2.8L V6
Tom how do you put up with the nice gas fumes from the extra spraying gas? I changed my filter yesterday and I think I lost a few brain cells, I just left the garage as soon as I could to let it all fall out on the floor.
Old Mar 25, 2004 | 07:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I actually do the filter outside... didn't want to blow up the garage!
And never set up an electric fan in the garage, either- the brushes from the fan motor could cause a spark and BOOM! An unhappy ending.
Old Mar 25, 2004 | 08:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I may be wrong but the only place you should find pressure is after the fuel presser regulator. So really just the fuel rails n such.
The pump would need to run 2 7 as I see no way it can / could hold pressure. I am not aware of any one way valves in the feed line. Opening the gas cap just lets air in tank. not really gonna help. as that little bit of vacuum can help hold the fuel in, instead of while you are changing the fuel filter, the open line creates a siphon cause of the lack of vacuum in the tank and gas runs all over the place.
Think most of that is right.
Old Mar 25, 2004 | 09:42 PM
JoshDT91's Avatar
Engine: 2.8L V6
Is there a reason the fuel filter flows in one direction and not the other? I know if you put it in the wrong direction fuel would never get to the engine but just curious if there was a reason for that.
Old Mar 26, 2004 | 01:25 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Actually, that's the only place you WONT find pressure. The only thing after the regulator is the return line.
There is a check valve inside the fuel pump. That is how the entire feed line stays pressurized.
BTW, I rarely depressurize a fuel system to replace the fuel filter. Not worth the time. Just crack the lines loose, then wrap a rag around it to absorb the fuel, slap the new one in and I'm done.
Old Mar 26, 2004 | 06:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My guess is that the filter's more efficient one way as opposed to the other way; other than that, I don't know. One day I'll have to cut open a fuel filter
Old Mar 26, 2004 | 09:53 PM
JoshDT91's Avatar
Engine: 2.8L V6
lol alright Tom.
Old Mar 26, 2004 | 10:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Some time the filters are cone shaped. The out side has more surface area. Like a clear brass slag cone motorcycle filtered.
Gas comes at the top of the cone, through and out.
Old Mar 28, 2004 | 08:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Hey I like Gumby's answer. Now I don't have to cut open a filter.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
