my car shakes?
Old Mar 31, 2004 | 05:13 PM
jcaldwell's Avatar
my car shakes?
It dosen't do it all the time, it only happens when I am at a complete stop with the brake pushed in. It idles at about 700 and the back of the car makes a rattling noise and there is a slight vibration throught the whole car, which seems to come from the rear. If I let off the brake or put it in neutral then the idle goes to about 850-900 and it dosen't rattle or shake anymore. Does anyone know what the problem could be? It is a 1992 3.1L automatic firebird with a flowmaster muffler. Thanks for any help in advance.
Jeff
Old Mar 31, 2004 | 05:42 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
harmonic balancer? motor/trranny mount?
hell, just let TomP guess it
Old Mar 31, 2004 | 06:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check the exhaust. It may be hitting someplace on the body/chassis. Go under the back and grab the tail pipes or muffler and shake it. It is hitting anywhere? Can you see marks where it may be hitting?
A slim possibility is that the tranny mount is broken (common). Typically this shows up as a thunk during aggressive take-off.
RBob.
Old Apr 2, 2004 | 07:59 AM
jcaldwell's Avatar
checked the exhaust and thats not it and i actually just got the tranny mounts replaced. Why would it only happen if it is in drive and the brake is on? If it is doing it and i shift it to neutral with the brake still depressed it stops immidiatly could it be the rear brakes? thanks
Old Apr 2, 2004 | 11:13 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Re: my car shakes?
Jeff
Motor mounts. Check the passenger side mount...it's probably tore up. The passenger side mount take the most abuse because of the way the motor spins. It will cause bad vibrations at idle in gear but it goes away off idle.
Old Apr 5, 2004 | 05:05 PM
jcaldwell's Avatar
How do I tell if the mount is bad? Will it be obvious just by looking at it?
Old Apr 7, 2004 | 09:29 PM
Engine: LH0 3.1L
Yeah, look at the rubber. If it's cracked, sagging, squished, then it's bad. Sometimes they'll be so bad that the engine mount bracket will sit on the frame. That's when it vibrates real bad.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
