carb + turbo
Old Apr 1, 2004 | 10:39 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
carb + turbo
i am doin a custom turbo this summer an i was thinkin bout goin to carbed as well. ihave been told however that it is not a good idea to have this combination. why is that? am i going to get more fuel through fuel injection or carbed?
Old Apr 1, 2004 | 10:48 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
good luck with the project. you either have to have a carb built to handle boost or you will blow air out around linkage,... or you have to have a carb bowl or dish or what ever they are called. the carb will have to be completey inside of something.
Old Apr 1, 2004 | 11:04 PM
RedTtop5spd's Avatar
Car: 99 SS
:werd:
It'll take a special carb to be able to do the job. IMO it would be better to stay fuel injected, just my own opinion from my research. Either way it's going to be a difficult task and take a lot of work.
Old Apr 2, 2004 | 12:07 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
take a look at the late 2nd gen Turbo T/A setup. It might give you some ideas.
And yes, you should have a carb specifically for forced induction applications in order to get the most out of that set up.
edit: also teh early T-Types & Grand Nationals too
Old Apr 2, 2004 | 01:30 PM
NHRATA01's Avatar
Well turboing a car isn't ideal, since its alot tougher to tune for varying boost levels and throttle input vs. a computer. But it is done, there are 2 ways - suck through and blow through. IE turbo behind the carb or in front of the carb. Most of the one's I've seen are blow through.
Old Apr 2, 2004 | 03:23 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
i did some research away back. Turns out you have to tap into the fuel pump and install an injector into the air duct. The injector will only cut on when under boost.
More info can be found here.
http://www.toohighpsi.com/BudgetTT/tthowto.htm
He did a twin turbo on a carbed 351. But its the same idea
Old Apr 2, 2004 | 03:43 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
That's a workaround for poor carburetor tuning/sizing. But it also illustrates why EFI is reccomended for turbocharging.. with EFI, you can simply reprogram the ECU to add additional fuel where needed.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
