Researched this thoruoughly
Old Apr 1, 2004 | 11:20 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Intake design is interesting to say the least. Making the runners bigger around tends to move the torque peak higher in the RPM band. Lengthening the runners causes the opposite. In other words, short runners = high RPM torque, long runners= low rpm torque. Fat runners=high rpm torque, skinny runners=low rpm torque. The speed at which the air is able to flow is greater with a smaller opening (hence the garden hose thing mentioned above). Just realized I made this a new thread.....Now I feel more ignorant than normal....
Old Apr 1, 2004 | 11:57 PM
RedTtop5spd's Avatar
Car: 99 SS
To continue with the explanation in regards to the length since the diameter has been explained...the length effects the low and high end due to the pressure reflections and when the pressure waves hit the intake valves.
Old Apr 2, 2004 | 12:21 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
good to know that I haven't forgotten everything from my fluid dynamics course 10 yrs ago
Old Apr 2, 2004 | 09:31 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Notice how certain 4 cylinders are getting longer intake runners now? Ever seen the runners on a new, I think, Toyota? Equal-length tubes branching off from a 'collector' right past the throttlebody. Looks so much like a header it's scary.
Old Apr 2, 2004 | 11:11 PM
FbodTrek's Avatar
And they tend to be pretty long
On import cars, the motors make power so hihg in the band, they HAVE to put super long runners in to make torque low enough to be useful...
Old Apr 3, 2004 | 03:50 PM
Nixon1's Avatar
Exactly. They're finally getting smart. And with how EVERYTHING seems to be getting VTEC, or variants like VVT, etc.....some of these 4 cyls are really starting to become contenders, as scary as that thought is.
Old Apr 3, 2004 | 04:04 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Let's not forget the variable intake runner setups on some cars... in combination with variable valvetrain technology, it's just kinda scary.. hopefully the Global 60* should include most of these technological milestones.
Old Apr 3, 2004 | 04:18 PM
Nixon1's Avatar
From what I've heard, it will! At least in some capacity.
Old Apr 3, 2004 | 05:25 PM
FbodTrek's Avatar
Makes me want
to go build a custom set of heads and an intake with variable runners to match it to.........hmmmmm. I think that'll be my NEXT project (the heads will have to wait though)
Old Apr 3, 2004 | 05:54 PM
Nixon1's Avatar
How about you go and build yourself a CVT with scotch tape, assorted size metal drums, and rubberbands?
How do you plan on doing the intake?
Old Apr 3, 2004 | 06:52 PM
FbodTrek's Avatar
Havn't decided yet
Although:
http://www.fiero.nl/forum/Archives/A...-2-014612.html
OR
The TPI hybrid intake seen before, (don't have the link). Both yielded decent gains, although the G-tch results are questionable. I've seen a few custom intakes made for the 60* V6. I've been educating myself on intake design. The jury is still out, needless to say.
Old Apr 3, 2004 | 07:02 PM
Nixon1's Avatar
It's hard to believe a slapped-together intake yielded a gain that massive..... I have a feeling the G-Tech was out of calibration. 40 hp from an intake? A lot of V8's cant even get a gain like that. And not to mention the intake hasn't even been 'tuned' so to speak...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
thejimsterz28
Sep 30, 2015 08:52 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Lmancha96
Sep 25, 2015 08:11 PM
