Ball Joints
Subscribe
Apr 7, 2004 | 10:25 PM
Are they riveted or pressed in to the knuckle? I would look myself but er umm.. I seem to be sans one floor jack after I moved recently
Just curious, because I suspect my lower joint on the driver's side is kaput, and I dont really have the means to punch out rivets.
Reply 0
Apr 7, 2004 | 11:33 PM
Pressed
If you don't have a hydraulic press, it's kinda difficult to do. I imagine you could hit em good with a sledge to knock them out, but getting them back in is the hard part. A press is really the only way to go.
Reply 0
Apr 8, 2004 | 04:42 AM
you can use a ball joint press and do them on the car. rivits can be cut, drilled or ground to remove, but you don't have rivits to worry about.
Reply 0
Apr 8, 2004 | 06:07 AM
Quote:
yes, that HUGE c-clamp looking thing. Not that hard to do, plus I think Harbor Freight is selling them for like $40 or so. Seen it somewhere. I scored mine as a damaged return from AZ. Took a dremel & cutting discs to fix the bad threads, he it ws good to go.
Reply 0
Apr 8, 2004 | 11:07 AM
Yea, I know what you mean. I use one in the shop frequently. I wish I could just take my car there to do it.
The shop in class, that is.
Reply 0
Apr 9, 2004 | 01:50 PM
On a tip from RBob, I smeared some anti-sieze on the new balljoint's flange where it pressed into the control arm. Lay down a lot of newspaper, you won't believe how much old grease is sitting up there!
I actually bought a balljoint press, got it for $100, and it was made by OTC. Lube up the threads with some plain 'ol engine oil to make things easier!
Reply 0
Apr 10, 2004 | 07:16 AM
Autozone rents that bad boy out... Leave deposit, use it, bring it back, get your $$ back!
Reply 0
Apr 11, 2004 | 09:14 PM
Yep, Pep Boys rents them out, too.
Reply 0
Subscribe
