high compression pistons
Old Apr 7, 2004 | 10:32 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
ok a couple questions here. first can we get high cmpression pistons on our cars im sure we can but where can we find them. also do we need to bore and stroke the block when we do this? is it going to increse fperformance by a noticible amount? and can u have high compression pistons and still turbo charge ypur car? thanks for the help.
Old Apr 8, 2004 | 04:45 AM
ede's Avatar
ede
most if not all piston makers will make anything you want. you don't have to bore the block unless there is wear that you need to remove. i doubt you can find a longer stroke crank unless you find someone to make one for you. normally you wouldn't want a high compression engine with most power adders.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
327IROC85
Sep 23, 2015 12:11 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ULTM8Z
Sep 16, 2015 09:15 AM
