bypassing the governor
Old Apr 11, 2004 | 02:55 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
i read the tech article on puttin in the on/off switch on the governor. is this goin to work with the v6 ecu? is the wiring different? and will the spedometer still work even though the governor is disabled?
Old Apr 11, 2004 | 06:13 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
if i'm thinking of the same switch you're talking about, it connects to the speed sensor on the transmission. your speedometer will not work and i think you'll get a check engine light but you won't have a 115 limiter.
Old Apr 11, 2004 | 06:53 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
wouldn't it be easier to just eliminate the limiter from your ECM prom? anyone in Virginia Beach need this done.. let me know!
Old Apr 11, 2004 | 08:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just put the switch real close and easy to reach. On the wheel would be good and just flip it off at 110 and back on once you want to slow down. After 100 does it even matter if you know?
Could hook up a mini spedo with a simple drive shaft sensor.
Old Apr 11, 2004 | 08:26 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
If the v6 has a 115 limit how come i've gotten my speedo all the way back around to 30- 35? Wish i had someone next to me with a high reading speedo on 95 when i did it.
BTW the car felt like it could of gone faster, i still had pedal left. I left off of it because at the time my tires sucked, one had a huge bubble in it!
Old Apr 11, 2004 | 10:32 PM
Car: 91 Camaro
the 3.1s with the 730 ecm had a 115 limiter, others may have been different. plus, we've got the 110 speedometers, brobert, you don't do you?
Old Apr 12, 2004 | 12:40 AM
br()bert's Avatar
Car: 85 firebird
nah, wish mine had numbers at least that high. I have the crappy standard dash with the huge gas gauge and 85 mph speedo. Its surprizing how fast it goes back around on the highway.
Old Apr 12, 2004 | 03:20 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Though remember people the reason they put these speed limiter in cars is so you did not go faster than the stock triers were rated for. The dealer just uses the cheapest tire it can and if they let you go faster than it can Hadle, it could be their fault.
Everyone should have z rated tires.
$750 L98
Feb 1, 2025 02:25 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Formula8r89
Sep 22, 2015 04:24 PM
HikoriYami
Sep 21, 2015 07:11 PM
