Idle drop on deceleration
Old Apr 13, 2004 | 08:19 PM
KayniacRS's Avatar
I have a 91 3.1 auto.
Ok so Sunday I cleaned out my TB and cleaned the IAC valve. I followed the instructions layed down by TomP and reinstalled. Like expected I got some problems idling at first, but mostly went away after a while. The car runs just fine now even at idle. However on any deceleration, or coasting at lower speeds, the idle drops and jumps and drops and jumps. At times it even dies. Am I expecting the idle to be relearn too quickly or is there a deeper problem here?
Old Apr 14, 2004 | 07:11 PM
KayniacRS's Avatar
Anyone? Anything? Im having trouble driving a parking lot and finding a space cause the RPM's dive so low it dies.
Old Apr 16, 2004 | 11:06 AM
KayniacRS's Avatar
So last night I give my buddy a jump. Car idled just fine while we had the cables hooked up, no problems. Then as I leave the car starts dying at every stop, and I throw an SES light. Problem is, I have no scan tool. This morning the light is gone but now RPMs are more irratic then ever. What is going on with my baby!?!!??!
Old Apr 16, 2004 | 11:50 AM
RedTtop5spd's Avatar
Car: 99 SS
Don't need a scan tool. Use a paperclip between the A and B terminals. Do a search and you can find more detailed information.
Old Apr 16, 2004 | 01:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
you didnt happen to use the battery ground cable as a welding ground recently did you?
Anyway, SAME exact symptom, I replaced battery cable and its gone.
Old Apr 16, 2004 | 01:43 PM
KayniacRS's Avatar
Thanks for the responses guys. Ill try replacing the cable and see what happens.
Old Apr 16, 2004 | 09:56 PM
KayniacRS's Avatar
Dale,
I didnt get the ground cable yet but when I suggested the idea to some people I got weird looks. Can you explain to me why this will correct the prob or what you think it might be.
Also, I read that the 3.1s require a scan tool for the ECM to relearn idle and what not. Is this true and are their any ways around it?
Old Apr 16, 2004 | 10:07 PM
Dale's Avatar
Engine: 350 S-TPI
read my post again, answer is in it
777Shock777
Oct 29, 2015 04:30 PM
db057
Sep 4, 2015 07:57 AM
greenyone
Sep 2, 2015 03:39 PM
IROCtometal
Sep 2, 2015 02:01 PM
