Check Engine Light
Old Apr 15, 2004 | 09:16 PM
6cyl92CamaroRS's Avatar
Car: 92 Camaro RS
Engine: 3.1 L
Check Engine Light
Hey guys got a question for you, I was getting my check engine light and was getting 33 which is the MAP sensor, and i found a broken vacume line fromt he manifold to the map sensor, so i replaced the hose with a bigger rubber hose connected to what was left of the old plastic hose. I ran my car alittle bit now instead of getting 100 miles to a full tank of gas im getting around 200 but still getting my check engine light and 33. What could be wrong???
Old Apr 15, 2004 | 09:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you remember to disconnect the battery to clear the trouble codes before you drove it again? If you didn't, the code will stay in the computer and continue to flash.
Old Apr 15, 2004 | 09:54 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
the code will stay in the computer but should not turn on the light unless there is still a problem somewhere.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
