Car is Messed up
Old Apr 19, 2004 | 07:09 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
Car is Messed up
OK.. PART1::when i start up my car it races to 2000rpm and then slowly drops down to 800rpm and then seems sluggish when i release the clutch. this only happens when starting up and getting to move, once moving its ok, except that sometimes when i push the clutch in between shifts the rpms go up to 2000or so? i pretty sure thats not suppose to happen. PART2::i have a short somewhere in the radio area i have installed, because when i move it like the check the wiring the accessory fuse pops( I'm Runnin low on fuses!). any help would be greatly appreciated
Old Apr 19, 2004 | 07:47 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i had the same thing w/ the rpm's. part of the problem was a carbon build up in the throttle body, the rest was a vacuum leak. clean out the throttle body and see what that does. if that doesnt fix it, start tracing the vacuum lines and look for a leak. if you have to, take some throttle body cleaner and spray along the vacuum lines and see if the idle changes at all. if it does, theres your leak.
Old Apr 19, 2004 | 11:19 PM
7plagues's Avatar
THANK YOU ill try that tomorrow Hopefully it works
Old Apr 19, 2004 | 11:24 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
i got a friend with an older accors he had some carbon build up as well. cleaned it out and got rid of the problem.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
mx127
Aug 10, 2015 08:13 AM
z28addict8490
Aug 7, 2015 08:48 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
