MSD cap and rotor
Old Apr 21, 2004 | 09:44 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
MSD cap and rotor
the msd p/n 8430 will fit our engines. yes, it is for a 4.3 but it DOES fit. i just put one on my car about an hour ago. the set was like $27 or so and that is the cap and rotor. i didn't think that they would fit either but, they do work with the electronic distributors. just thought i'd throw this out as FYI since it does occasionally get asked about.
Old Apr 21, 2004 | 10:04 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well thats great to know
Old Apr 22, 2004 | 12:10 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Sweet deal
Old Apr 22, 2004 | 07:13 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Sweet! I'll have to order that in, and inspect it against the $16 Conrad cap/rotor I've got now
Old Apr 22, 2004 | 09:22 AM
Car: 91 Camaro
they look exactly the same. the conrad, mine anyways, seemed to be a little bit darker red....only difference i noticed. but, i tried checking my old cap and wires for resistance...i couldn't even get a reading on a few of the wires and some of the terminals on the cap....think that was hurting any power????
Old Apr 22, 2004 | 09:24 AM
Doward's Avatar
Check the wires from terminal end to plug end for resistance, and then check the cap itself, from the inside to the post, for resistance...
I wonder if the brass ones conduct better or no?
Old Apr 22, 2004 | 09:29 AM
Car: 91 Camaro
i checked them seperately. some of them, i had to cut about a half and inch off of the dist. end to get anything. three of the terminals on the conrad cap were all rusty/corroded. i checked resistance on the msd cap and the wires as i put them on....very little, next to none.
Old Apr 23, 2004 | 05:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sweet, thanks for the info, AM91Camaro_RS!
As far as not using a brass cap, if you have an MSD ignition: http://www.geocities.com/tomp_3rdgen/burnt-cap.html
Old Apr 23, 2004 | 08:40 PM
RedTtop5spd's Avatar
Car: 99 SS
Dang. before I install my blaster 2 coil I know I'm going to get a new cap and rotor.
Old Apr 23, 2004 | 08:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That happened with a full ignition (6AL box and Blaster SS coil), before that I had "just" an Accel HEI Supercoil, and I'm pretty sure I used a normal cap/rotor at some point. Your stock cap might be okay with just the aftermarket coil.
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tyeo098
Nov 30, 2015 06:27 PM
BLK87Z
Sep 18, 2015 11:29 PM
m00n420
Sep 11, 2015 02:39 PM
