Oil sending unit??????????????
Old May 8, 2004 | 12:47 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I was checking out my friends V6 and noticed his car was slightly smoking on the drivers side and it stopped smoking,so we opened the hood and found no oil leaks or anything visable ,so is it possible that the oil sendeing unit that is connect to the oil filter connector might be defective?...and if we change this,would it stop the smoke since the source apears to be coming from there?
Old May 8, 2004 | 01:43 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Verify that the sending unit is on tight, also the oil filter while your reaching there.
Old May 8, 2004 | 10:52 AM
92RSSlowmaro's Avatar
My oil sending unit went bad, and caused a steady leak on that side of the motor. Whats the mileage on the car? Its very likley that it may have gone bad.
Also, i'd just replace the thing anyways. Their 3 bucks at autozone.
Old May 8, 2004 | 07:50 PM
sheltonw3's Avatar
Engine: Classified
its over 108.000 right now and the car runs real good and all and the oil gets changed every 3 months with rislone added at each change!....well if it is that part ,then we'll just have to change it and the oil as well!...thanks guys!
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
