diameter of y-pipe???
Old May 12, 2004 | 06:57 PM
squirrelybird's Avatar
what is the size of the stock Ypipe on a 91, at the connection point to the cat? meaning outside diameter? for example, if i were to replace the cat with a pipe, what size would the pipe have to be to SLIDE ONTO the y pipe?
thanks
Old May 12, 2004 | 08:10 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Stock?
The Y pipe is a pipe in a pipe.... inside diameter is what you need. All the ones I saw were 2" (ID)
Old May 12, 2004 | 09:06 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Tiny?
2" sounds right, or 1 7/8ths
Old May 12, 2004 | 09:56 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
more like 2 1/4" Go to parts store & ask for replacement convertor. It will be a slip fit your looking for. Measure that.
Old May 15, 2004 | 11:08 PM
Engine: 5.7 / 7.4
http://www.catalyticonverters.com/PO...D41158389.html
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
roysatikas
Sep 22, 2015 08:15 PM
Camaro_383
Sep 11, 2015 11:28 PM
