question about relays
Old May 15, 2004 | 08:13 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
On the driver side near the power brakes i have 3 relays,2 are the same and one just look like to that one from the maf at the right side near the battery.so my question is about the two that are the same what are they for.I have found o lots of grease on the terminals and some bypass.The one for the cooling fan also has a bypass on it that's why the fan kicks on when i turn the car on.Any idea how to fix that,the relay i just changed but the fan when i disconected the bypass did not worked
Old May 15, 2004 | 11:44 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Those relays near the brake booster are for the fan, fuel pump and a/c.
Old May 16, 2004 | 07:46 PM
BitchinRS's Avatar
I have a fourth one on the pass side by the blower motor. Any ideas what it is? Couldn't find it in any of my books. 1992 3.1lL
As far as it not working after replacing the relay are you sure the temp sender is function correctly? If not it could be the source of your problem. I had a pretty messed prob with mine. Both the temp sender and the temp gauge were bad. The temp gauge would read high. Drove me nuts for a while/
Old May 16, 2004 | 08:02 PM
Engine: 3.4L 207 V6
The relay mounted by the blower motor is for the high speed of the blower motor.
Old May 17, 2004 | 04:48 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
i'll check and change that also.
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
