Map/maf
Old May 20, 2004 | 06:39 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
Map/maf
Do the 3.1s have a MAF, or do they just use the MAP sensor, because I was told to check my MAF due to a problem but I don't think i have one.
Old May 20, 2004 | 06:52 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
pop the hood look at the intake ducting, if you see somthing that looks like a big black plastic coffee mug thats says maf on it its your maf.
Old May 20, 2004 | 07:12 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
90+ are MAP-only stock. Check the vacuum line to your MAP for cracks or loose rubber connectors.
Old May 20, 2004 | 07:16 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Who told you to check your MAF? They weren't looking under the hood at this point in time were they?? If so, disregard their comments, close your hood, get in the car and drive away briskly.
But seriously-what made them say to check it. A check engine code pulled, something about the way the car ran, etc.?
Old May 20, 2004 | 11:28 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
same problem i have posted on her a few times, the engine speed slowing down while i'm driving like someone was forcing the throttle back up when i had it at a cruise, it lopes. and no the hood wasn't up,
and i took off the hose to the map and blew through it, its clean with no leaks
bzdart1974
Dec 24, 2011 02:19 AM
Black'92
Apr 28, 2011 03:22 PM
Ob_one
Nov 23, 2007 09:49 AM
chevman
Sep 5, 2004 06:22 PM
