Timing Chain might be bad?
Old May 20, 2004 | 06:55 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
How long does it take for a timing chain to go bad? Is there anyway to check it?
Old May 20, 2004 | 06:59 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
How many miles is your car? Timing chains are generally hard to snap, but stretch on high mileage chains is not uncommon. Pull your distributor cap and try to turn the rotor...it should not move very much. The, if you can, have somebody (or if youre extremely skilled), turn the crank pulley with a breaker bar, etc. as you watch the rotor. The rotor should start to move almost immediately. If not, the difference is chain slack.
I usually recommend replacing them over 100k.
Old May 20, 2004 | 09:55 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Replace mine every 60k-75k miles....
Old May 21, 2004 | 12:50 AM
92RSSlowmaro's Avatar
Mine snapped at 112k.
Old May 21, 2004 | 12:54 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Arg... need to replace mine soon then, because mine has 112k! Was planning to do it this summer, don't fail me now chain, just 4 more weeks of school!
Old May 21, 2004 | 09:39 AM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
Mine just passed 100K so i guess ill try your test and see what i can see.
Old May 21, 2004 | 11:09 AM
NHRATA01's Avatar
Mine's at 120k, hasn't snapped yet, never heard of too many breaking. Timing chains often outlast the rest of the motor. My first car was an '80 Chevy Caprice, 3.8 V6 that was passed around the family, had 227k miles when I got rid of it, never touched the timing chain. Certainly stretching is very possible tho, might be part of the reason why my car is running poorly.
Now belts OTOH that most imports use are at risk of breaking over 60k miles.
Old May 21, 2004 | 11:18 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Mine had almost 200k (as far as I know it was stock) and was looser then a french ***** . So loose that it started snapping the plastic off the guide and hitting the TC cover. It still ran, but was soooooo much better afterwards.
I belive gm recommends 60-75 on them.
Old May 21, 2004 | 12:05 PM
Honestly, I think mine broke because some water somehow slipped past the front engine cover seal, and froze on the chain itself, causing it to expand and break when I cranked it over the next morning.
This is just a theory, though.
So you may have nothing to worry about.
Old May 21, 2004 | 12:16 PM
89V6FBIRD's Avatar
I was planning on replacing it soon anyways! Just haven't had the time (school) and since its a daily driver, I need it to get around. This summer will be good though, because I might be able to drive around the T/A for the 2 days that I'll work on the chain.
Old Oct 4, 2004 | 02:50 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
What did or didn't your car do when it snapped? How did you know it was the timing chain?
KZad
Old Oct 4, 2004 | 05:33 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
thats a pretty good methid of testing
Old Oct 4, 2004 | 07:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I changed my stock one out at 167,000 miles. I've been on the Cloyes True Dual Roller chain ($90) since then, and now I've got 272,000 miles on the car. Rock on!
Old Oct 4, 2004 | 07:20 PM
Nixon1's Avatar
You guys are resurrecting a dead post!
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
