Ac compressor
Old May 23, 2004 | 10:35 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Ac compressor
How do you tell if that unit is bad. The unit that the belt rides on. Mine was knocking at one point but is not now. I'm wondering if its bad. I look at it with the ac on and with it off, i see no difference, should there be something i should see? Thanks
Old May 23, 2004 | 11:09 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Do
Do you still have cold air? If you do, it ain't bad yet
Old May 23, 2004 | 05:57 PM
Engine: 2.8 Lt
Transmission: 5 Spd
got no cold air , lol
Old May 23, 2004 | 05:59 PM
FbodTrek's Avatar
It's gone
If there is still pressure in the lines (check at the low side), Go ahead and get yourself a Compressor.
Old May 23, 2004 | 07:48 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Where is the low side? Shouldn;t u see that clutch spinning? Or it should look different when the ac is on right?
Old May 24, 2004 | 05:36 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
yea, you should see the clutch spinning. you should also hear it clicking off and on. make sure both plugs are still plugged in too.
Old May 29, 2004 | 09:38 PM
Akshay's Avatar
If it's bad, it should be leaking....right?
You should see lots of moist dirt build-up at/near the compressor's clutch/pulley.
Old May 29, 2004 | 09:47 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I cleaned it about a month ago so it is still clean, i do not see the clutch spinning at all and don;t here anything? Still bad? Thanks guys
Old May 29, 2004 | 10:06 PM
Akshay's Avatar
Like FbodTrek said, check the lowside. The lowside is the bigger hose/pipe going into the compressor. You should be able to get a gauge that screws into the lowside plug.
Old May 29, 2004 | 10:09 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
IIRC, according to a way old out of date manual I have (this is older than our thirdgens folks) the low side fill port is the valve on the top of the silver accumulator thing, next to the heater control valve and box. The pressure is checked here as well as filling. You need to purchase an A/C pressure gauge, which is marked in "HI" and "LO" graduations. The LO one is used here...
Old May 29, 2004 | 10:37 PM
FbodTrek's Avatar
Or
Or you just shove a pen cap in there to push the valve in, ou'll know if it has freon....
Old May 29, 2004 | 10:39 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If you want to do the above, don't use a pen CAP, use a bad pen. You definitely don't want to freeze your fingers off when the freon hits them...
Old May 29, 2004 | 11:05 PM
Akshay's Avatar
Also, I don't think the compressor will work if you don't have freon (because of a leak somewhere).
Try adding freon that comes w/ dye (sp?).
Old May 30, 2004 | 12:21 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
yeh, had that experience last year, i took the car to a shop to have them look at the A/C unit cause it wasn't working anymore. Guy probed around the engine, checking current at different relays, saw that i was getting power just about everywhere, minus the compressor relay, he hit it w/ a hammer, and boom, compressor kicked on, then right back off...it was short cylcling, which it'll do if there's not enough freon to keep it running, i took it and did the 134A conversion, and i had good working A/C...then the engine started leaking oil, shop had to pull the motor, and the next thing i know, the A/C isn't working anymore...didn't work the rest of the summer, winter, or not....and will no longer take a charge...guess i'm stuck going to a shop to have it fixed up now.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
