3.4 intake
Old May 23, 2004 | 08:09 PM
Rebel 92 F-bird's Avatar
Car: 92 F-bird, 1965 Goat (GTO for those who don't know what a Goat is.)
Engine: 3.1 V6, 400 w/3 2 bbl's
Transmission: 700-R4, TH350
3.4 intake
Will an intake manifold from a 4th gen 3.4 work on our cars? I know that the heads will and i was just wondering about the intake.
Old May 23, 2004 | 08:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
No, rear crossover will not allow the distributor to fit.
(insert obligatory "search" comment here)
Since your post counts shows you're new, Welcome!!!!!!. THe comment above can be your best friend (provided you can figure out how it wants you to search & are ready to sift thru the countless threads it will provide )
edit: All members that have cars w/6packs on them are required to provied pics
Old May 23, 2004 | 09:47 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Actually, I think a more appropriate answer to this question is:
If you want to change over the ENTIRE engine control suite to the 3.4 version, then yes it will fit. The 3.4 does NOT use a distributor but uses coil packs instead and has to have computer control over them. The intake is designed to fit around the coil packs (I would guess and I believe that is what I've heard) and the rear bar, like mentioned above, will get in the way of dropping the distributor in.
If the above is too much work, then just keep what you have. I don't think the heads are really that much of an improvement over stock 86-92 2.8/3.1 1.72/1.42 heads, but I could be wrong.
Old May 23, 2004 | 09:58 PM
oil pan 4's Avatar
Car: 89 Firebird
Yes it will bolt on there but like they said no distributor.
I have 2.8 heads, a 3.4 intake manifold and 2.8 plenum, some improvement maybe.
The 2.8 and 3.4 heads are the same thing.
Old May 25, 2004 | 09:13 PM
The GTO is a restoration project that I've just started on. My dad gave it to me because he doesn't have time to work on it anymore. It's in a pretty rough shape right now, but it's an origional 6 pack car and I've got all the parts.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
