how do i know 2 set timing?
Old May 24, 2004 | 11:08 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
how can i tell the timing is off? i think it could be off but not sure. the idle is up and down in drive gear and jumps slightly and comes back down. ive changed many parts on the car not for this purpouse but 4 maintinace purpouses. whats making the idle go up and down while in drive? ive put a new IAC on 7month ago but does that have to be set right with somthin? if so, please tell me how 2 do it.
Old May 25, 2004 | 01:41 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
on my 89 2.8 (not sure what you have) disconnect the est wire (brown and tan wire back by passenger side firewall), use a timing gun and set to 10 degrees. 11-12 if your timing chain is really old. shut car off and reconnect wires.
Old May 25, 2004 | 02:20 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Advancing it a few degrees will help low end. If you start to ping or feel the power flatten out at top end then back it off a degree of two until it feels better. Stock timing calls for 10*- I run 13* some run as high as 14.
Old May 25, 2004 | 11:00 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
good lookin out yall
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
