throttle cable sticking a bit
Old May 25, 2004 | 05:13 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
when i let off the gas and push in the clutch the idle stays at about 1500 to 1800 rpms. if i lift up on the pedal and slightly to the side, it drops to normal. anyone else have this problem? i lubed where i could on the cable but nothing. if i rev the engine w/ the throttle body, it doesnt do it, so its in the cable somewhere. anyone else have this? i think im gonna have to replace it.
Old May 25, 2004 | 11:15 PM
Akshay's Avatar
Spray a little TB cleaner inside the TB. And did you lube the gas
pedal?
Old May 26, 2004 | 08:26 AM
drdave88's Avatar
Engine: 6.0L
its not the throttle body, cause if i operate it from there its fine, its only the pedal. and yes i did lube the pedal too, forgot to mention that.
Old May 30, 2004 | 10:09 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if it were me id run down to the parts store and pic up the new throttle cable and be safe because i had this happen once and it sucks to be going down the road and have someone else stop in front of you and you hammer the brakes and the throttle is still trying to go ......
its more of a saftey issue to me
if it is acting up at all then there is something wrong with it that needs to be addressed instead of fixed for the time
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
