TPI air intake conversion
Old Jun 5, 2004 | 09:00 PM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
I have a 92 camaro with the 3.1 v6. i heard that the dual snorkle on the TPI camaros can be put on to the v6 to increase HP so i bought one and the stock air intake tube doesnt reach the snorkle. can the dual snorkle be hooked up ? what do i need to hook it up properly ? i have an AIM s/n of Camaro RS 8992... you can IM me if you have any information that can help me out
Old Jun 5, 2004 | 10:25 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
with the 92 Camaro, you have no MAF...that's a good thing for ease of hookup. i went to homedepot and hit the plumbing isle for that setup on my 3.1. 3" pvc pipe and 2, 3" straight thru rubber couplers. that will squeeze down to fit over the TB. i have pics of this setup on page 3 of my cardomain site, my cardomain site . good luck and welcome to the boards.
Old Jun 5, 2004 | 10:27 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have 2 pictures on this page on my site. they show the two different ways I had mine.
:edit:
Old Jun 6, 2004 | 07:59 AM
Car: 92 camaro RS
thanks !
thanks for the help... i like the chrome plenum and alternator and the painted snorkle looks sharp... i eventually want to get around to dressing the motor up but im still working on restoring the car
Old Jun 6, 2004 | 08:02 AM
Car: 92 camaro RS
i have almost the identical exterior with the artic white exept i have the red stripes and the bowtie grill
Old Jun 6, 2004 | 10:40 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
For the sake of helping a new member learn to keep the boards remotely tidy. The last time I tried to merge a pair of threads, the result was disasterous , so I'm just avoiding it now
Originally posted by camarors8992
i went along and bought some 3 inch pvc with the 3 inch couplings...but i noticed that theres a tube from the valve cover to the old air hose... this cause a prolblem because i dont want to cut a hole in the coupling... is the hose nessesary... ? any help would be apreciated
Old Jun 6, 2004 | 10:45 AM
TechSmurf's Avatar
Engine: LS1, Scrap
The tube you're referring to is your PCV breather inlet (positive crankcase ventilation, not PVC (poly-vinyl chloride) (yes, the two terms become extremely confusing at this point since we're now referring to both)). A source of filtered air is required for the PCV system to work. In stock configuration, this is done by the forementioned tube. I'm not sure how other members have set this up, though, so I'll just let them chime in, since I've had pretty horrible luck fitting a breather filter between my plenum and EGR/coil bracket, and connecting the tube back to the intake tract *does not* work in turbocharged applications (I'm running no breather filter, but my motor is *FRIED*, do not try this at home)
Old Jun 6, 2004 | 12:36 PM
Car: 91 Camaro
the edelcbrock chrome valve covers only have one hole in each cover. the one on the driver's side will have the pvc (i think, or pcv) hose or valve and the cover on the pass. side, i just have a oil cap on it. i did not run that stock tube back to the intake.
Old Jun 6, 2004 | 07:30 PM
Car: 92 camaro RS
got the snorkle air intake put in !
today i put the v8 air intake in... i ran up to sears hardware and bought some 3" PVC and to boots that were $7.00 each and drilled a hold for the valve cover breather...the siliconed it up....it looks funny but i will put a coat of black paint over it to make it look a little better but i could feel the difference in the car... it has more touque and it even sounds better thank you for the help i wouldn't of been able to do it without the help
my car still runs very rough and almost stalls when it is put in gear and the brake is held...im gonna try to put new plugs in it...i hope this fixes the problem... the fact that the car sat for three years...and the gas went bad and we never fully got the gas out... but the injectors have been cleaned several times new cap and rotor have been put in and new plugs wires... i have gone through more that 20 sets of plugs including $60 worth of splitfire plugs and the motor still runs rough if you have any tips that may help smooth it out please let me know
Old Jun 6, 2004 | 07:33 PM
Car: 92 camaro RS
eldebrock valve covers ??????
i didnt know elebrock made valve cover for the 3.1 v6 ive searched all over for valve covers cause the stock covers and ugly... can you direct me to where i can buy them and how much $ are they
Old Jun 6, 2004 | 07:49 PM
Car: 91 Camaro
sometimes you can find the edelbrock valve covers on ebay.
Old Jun 7, 2004 | 08:09 PM
Car: 92 camaro RS
thanks
thanks to all of you who helped me understand how to install the v8 intake
Old Jun 7, 2004 | 08:34 PM
Car: 92 camaro RS
hey dale the pontiac fieros valve covers fit on the 3.1 camaro ?????
Old Jun 7, 2004 | 08:55 PM
Dale's Avatar
Engine: 350 S-TPI
yes they do
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
