what yall use for the summer time?
Old Jun 9, 2004 | 03:30 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
what oil is everyone using for the up coming hot conditions?
Old Jun 9, 2004 | 04:14 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I use an SPF-30 waterproof, and keep some aloe handy when I miss a spot and burn
Seriously, use 15w-40 year round. I'm old enough to remember dad having the 10wt in the winter and the 30wt in the summer.
Eric
Old Jun 9, 2004 | 06:14 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
is castrol sytec good? is syntec the same as sythetic? is that the same name?
Old Jun 9, 2004 | 08:16 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
ive always run what GM recommends for the engine, 5w30. i use valvoline durablend. i think anything more than 10w will be too thick, unless you have some serious clearances or oil consumption. but for a normal engine, i would go thicker than 10w30.
Old Jun 16, 2004 | 07:45 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
in my camaro i run 5w30 synthetic all year round (i try to put it away when it snows here in canada depending if i have another car or not)
Old Jun 16, 2004 | 09:20 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
note: if you run synthetic oil- you have to run higher weight because it is thinner and flows easier, thus creating a slight loss in oil pressure. Hotter climates and hard driving call for a heavier weight oil.
I run 15w50 Mobil one full synthetic. I have an '89 chev truck (350) that has OVER 400,000 on the original bottom end bearings, etc... all from full synthetic oil.
Old Jun 17, 2004 | 05:31 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I usually do 10-40w Mobil One for the summer and then 5-30w for the winter. Stupid New England, 100 degree summers and 5degree winters.
Old Jun 17, 2004 | 12:22 PM
devianb's Avatar
I use 5w30 year round but in the summer time I may dilute the 5w30 with a little 10w30 but not full 10w30.
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
