if swapping to carb...
Old Jun 13, 2004 | 09:26 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i've got the whole edelbrock carb setup and a holley 4 bbl carb, as well as vacuum adv. distributor. i know i'll need cowl hood for clearnace and a fuel pressure regulator with a return line ( to avoid droping tank again). what about my speedometer and VATS? what can i/will i need to do here?
Old Jun 14, 2004 | 12:08 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Good question. I would think your speedo would still work. Mine doesnt but i went from a 85 2.8 to a much newer v8. My car had a cable driven speedo, the new trans is vss. Your just doing an induction swap. As long as you dont go wire cuttin crazy i would think you'd be ok.
Project mentioned something about a vats bypass module or something like that to me when i was doing the swap but i didnt use any of the v8 tpi stuff. Instead i went right to carb (3 wires woohoo!!!)
Anyone else know for sure?
Old Jun 14, 2004 | 08:49 AM
Car: 91 Camaro
but mine is vss and the computer won't be hooked up.
Old Jun 14, 2004 | 11:04 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Curious
Why ya swapping to carb? If the tranny is VSS, you should be able to get a reading from the sensor itself with an aftermarket gauge. Let me know how it goes.
Old Jun 14, 2004 | 12:54 PM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
If your speedo is cable driven and the ecm is not in use/installed, the vss will not work but the speedometer will work anyway. It is just like plugging an air rail for a smog pump system but it is still on the car.
Old Jun 14, 2004 | 01:47 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
As long as it's powered, the VSS should still drive the speedometer... I'm not sure if the VSS gets its power from the ECM or not, but I'm fairly certain the signal goes from the sender to the speedo, and then to the ECM... so the ECM is not key to the speedometer's function
For VSS, you'd need to either remove the VSS system, or leave the ECM in, or find an aftermarket solution.
Old Jun 14, 2004 | 01:59 PM
Car: 91 Camaro
FBOD, i'm wanting to swap to carb to see if i can get more power out of my setup. i think i might be able to get it solidly into the 14s with a carb on it.
techsmurf, i hope you're right. i hope the sensor sends the signal to the speedo then to the ecm, that'll be fine. and, what do you mean by the last part of your post, "For VSS, you'd need to either remove the VSS system, or leave the ECM in, or find an aftermarket solution"? are you refering to VATS but accidentily typed VSS? if not, please explain.
anyone able to tell me what i need to do about VATS?
Old Jun 14, 2004 | 05:20 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Alan, no need to worry about the speedo. As long as the VSS is in the trans plugged in and the little white box (some call it a DRAC, what ever that means, some call it a speedometer signal buffer) is connected under the dash it will work. My S10 has no ECM and the speedo works fine. The temp gauge and gas guage were messed up when it had the awesome 2.5 in it.
Old Jun 14, 2004 | 05:58 PM
Car: 91 Camaro
cool, thanks Eric.
will VATS still be there and functioning or will it cause problems for me?
Old Jun 14, 2004 | 06:07 PM
TechSmurf's Avatar
Engine: LS1, Scrap
oops.. VATS
Old Jun 14, 2004 | 06:18 PM
Car: 91 Camaro
Originally posted by TechSmurf
oops.. VATS
ok, cool. so, just leaving the ecm there will allow VATS to still function? if so, that's no problem, i can leave it in there.
Old Jun 14, 2004 | 08:59 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Yup
Old Jun 14, 2004 | 09:59 PM
Car: 91 Camaro
awesome, thanks.
Old Jun 14, 2004 | 10:23 PM
br()bert's Avatar
Car: 85 firebird
Just curious , what afpr are you going to use?
Old Jun 14, 2004 | 10:24 PM
Car: 91 Camaro
i don't know yet...haven't really looked at them too much, yet.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
