Towing with a 2.8 WC t-5?
Old Jun 18, 2004 | 11:00 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
WHat do you guys think. I have a trailer hitch on my car, do you think i could tow with it?
Old Jun 18, 2004 | 11:08 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yea. But the load on the car is important. Best to have a trailer that low and has more then 2 wheels. So most of the load is on the trailer and not the tongue / rear end of your car.
Old Jun 18, 2004 | 11:14 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
A jet ski or a small fishing boat at best.
BTW MOST trailers that have more then two wheels ( dual axels) are WAY too heavy for a 2.8 to move.
Old Jun 18, 2004 | 11:46 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah. I have tow hitch off an Iroc z i want to put on it, Just for towing small things if i need to. Like wood, or something. Thanks guys
Would the T-5 hold up?
Old Jun 20, 2004 | 08:07 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
get a tranny cooler and remote filter and it will for sure
Old Jun 20, 2004 | 08:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Never seen those on a stick but if you say so.
You should be ok as long as your not jerking heavy loads. The sheer strength of a 6 penny nail is 7000lbs. Those bolts are much bigger and what, atleast grade 5.
if you fell the need drill more [2-3 a side] holes and add more bolts. Grade 8s if you can find them. But I think you are right as them two small front bolt just hold it up. Your big 4 are for pulling load.
Just keep the load on the trailer and do not jerk things around with it.
I say that as I ripped the bumper off my Buick wagon that way. It has the factory tow package and the ball was just bolted to the steel bumper. But the bumper support was made from aluminum and then bolted to my steel frame. steel bolted to aluminum that is bolted to steel is not good for pulling tree stumps.
I wrapped the chain around the rotten tree. [bad rotten soft n spongy] stepped on the gas and ripped my bumper off.
That's always neat.
Old Jun 20, 2004 | 09:00 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
But did the stump come out?
Old Jun 20, 2004 | 10:22 PM
Engine: 2.8 Lt
Transmission: 5 Spd
LOL, Thats not good. The bolts on there are pretty big and i think it will work. I put a lock washer right befor the nut, so the wash is up against the frame. I think this should stop it from coming loose. Thats where that washer should go right? I think I will leave those other two disconnect, so that if the bolts break or something, they won't rip my bumper off. LOL They are small and i doubt would help anyway, don't know what they aree for, like you said, I should be could with the 4. Thanks
Old Jun 20, 2004 | 11:34 PM
Car: IROC Z
Engine: 5.7
my dads 1979 1 ton dodge ramcharger 3 speed had a tranny cooler. they were put in trucks all the time. towing package?
they have one for the corvette
http://www.gmpartsdirect.com/results...umber=12480080
ill keep looking
im sure you can make one
heres a passive ambient one...
http://www.dieselsite.com/miscprod/fastcooler/
not what i meant though...
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
dimented24x7
Sep 17, 2015 06:58 AM
DARKmj16
Sep 9, 2015 04:07 PM
