Air Filter help
Old Jun 27, 2004 | 02:23 AM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
Air Filter help
i have a 3.1 v6 with a TPI intake and which air filters would you recommend ive herd only good things about kool blue and K&N
Old Jun 27, 2004 | 02:27 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
The oil in the K&N can ruin your mass air sensor!
I went back from K&N to a plain old stock paper filter to avoid that!!
Old Jun 27, 2004 | 02:46 AM
Car: 92 camaro RS
i have the old paper AC Delco on my car now but im looking for a little more power, do you know any other brands that will help my car breathe just a little better thanks for the quick response by the way
Old Jun 27, 2004 | 03:27 AM
If your engine is stock, you won't get any power gains bij fitting a so called "performance filter".
Keep the original Delco, and change it at every tune up! (like every 5000-7500mls)
Old Jun 27, 2004 | 06:53 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I've had K&N for almost 3yrs on my car, granted I don't have MAF but I've had no problems.
Old Jun 27, 2004 | 03:03 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
First, the V6 MAF isn't a hot-wire style MAF... I *seriously* doubt the frequency film is going to give a damn about a little filter oil. Second, he has a 92... what MAF?!
Regardless, the performance benefits of better filtration in the dual snorkel setup are debatable. The paper filters flow enough to feed a 350, though probably with a pressure drop... the pressure drop is likely negligable with a V6 (always meant to hook a MAP up to the intake tract and find out, but it's a little late for that now). With a good filter hurt performance? Probably not. Is 2 hp worth 80 bucks? That's a question only you can answer.
Old Jun 28, 2004 | 03:28 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
With the K&N though you can recharge them for a fraction of the cost, so while it may cost $40 for the filter in the first place you can recharge it later for much cheaper.
Old Jun 28, 2004 | 05:08 PM
Car: 92 camaro RS
thanks for the help but does any one know anything on kool Blue
Old Jun 28, 2004 | 07:51 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
here's a easy way to tell performance. i have paper filters in mine, i have run it at the track with those and with no filters and not seen a difference.
Old Jun 29, 2004 | 05:39 AM
TechSmurf's Avatar
Engine: LS1, Scrap
IMHO, due to the fairly limited amount of technology you can put into a cotton gauze filtration element at this point in time, I would have to say I believe that *all* high end cotton gauze filters are created equal. K&N, Accel's Kool Blue, Fram Air Hogs... the only differences that can really occur are the density of the element (not likely to vary much), the material used to force the cotton to keep its shape (probably a metal mesh on all 3, and I'm not going to nitpick on the material used when it constitutes less than an ounce of metal), and where the cotton was grown... oh! And the most important feature.. the color!!
Old Jun 29, 2004 | 03:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's my take:
They're good to have, but you probably won't feel a difference unless your old air filter was clogged to hell.
Old Jun 29, 2004 | 04:15 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
when i swapped my stock intake, to k&n open element.. i know i felt a difference.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
