Whistling sound (I wish it was from a turbo)
Old Jun 30, 2004 | 08:52 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
I have this wierd whistling sound from my car now after I did my tuneup. I was thinking that maybe it was from the k&n air filters because they have those seals.
It kind of sounds like a turbo which is good but my car is still slow, which is not good...
Anyway, any ideas on what the whistling is?
Old Jun 30, 2004 | 11:01 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
filter
Old Jun 30, 2004 | 11:12 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
at the same time, could be a bad vaccum leak, make sure u didn't knock any vaccum lines off when u did the tuneup, especially in the area of the EGR setup, as those could easily be pushed when yanking out sparkplugs....could be your filter, but unless you're running an open element (which you might be) you won't hear it, even if you have a K&N.
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
Blue419
Sep 10, 2015 01:03 PM
84 TA NV
Sep 6, 2015 08:02 PM
