Bad Idle and no cause in sight!!!
Car: 1992 Camaro RS
Engine: 3.1 MPFI
Ok so my car runs bad at idle and has a slight misfire at mid rpms. Ive checked EVERYTHING i could possible think of: Timing, injectors, fuel pressure, evap system, pvc, spark plugs, dist cap......is there ANYTHING else im missing?
Car: 1992 Camaro RS
Engine: 3.1 MPFI
no, no codes
do computers just go bad out of the blue? Or by jump starting it? This all seemed to maybe have started when i jumped it.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
A LEAK FROM YOUR POWER BOOSTER COULD CAUSE IT CHECK THE HOSE AND WERE IT PLUGS INTO THE BOOSTER.
Car: a car being parted out
Engine: blown up
Transmission: in peices
Originally posted by 3.1RS
What????
What????
A simple test is to get the engine dead cold and remove the plug. Drive around, and if the problem goes away, you got the culprit.
Engine: blown up
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
what about a MAF? didn't see it in your list. mine had a miss in mid RPM's as a result of a bad MAF, it actually has a minor and occasional miss right now in mid RPM , and is a little sluggish off the line (closed loop operation) and i'm thinking it's related to the bad O2 sensor it has right now...another possibility.
Engine: 2.8L, LS1
Fast, i'm in my on lala world....didn't even notice the year or engine.
happens to the best of us, i hope.
Engine: blown up
Originally posted by V6sucker
the EGR could be sticking and not closing when it should be. The excess vacuum it creates by staying open wreaks havoc on the timing.
