3.1L Vacuum Lines
Old Jul 19, 2004 | 09:57 AM
rsttop's Avatar
Car: 1992 RS Camaro T-Tops
Engine: V6
Transmission: 5 speed
3.1L Vacuum Lines
Hey whatsup everyone. I was just needing some help with this topic. I figured this the best place to get the info I need. I am just trying to find out where the vacuum lines for a 3.1L go. Theres three lines behind the throttle body and two lines behind the plenum. If someone could just tell me where each one goes, and if it splits into a T or if its just straight from here to there. Also if you could say if its like the line on the drivers side or the passenger side, so I don't hook up anything wrong. A vacuum diagram would be nice also. My hood was replaced before I got the car and is missing the diagram. Thanks for any help on this.
Old Jul 19, 2004 | 10:45 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
1. this is a double post.
2. the last topic you posted this question in had the answer IN IT if you would have read it.
Old Jul 19, 2004 | 10:53 AM
rsttop's Avatar
Engine: V6
I did read my previous post thank you. On that one though, it says there are two lines coming out of the throttle body, but isn't there three of them. I just wanna know man.
Old Jul 19, 2004 | 11:54 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
The throttle body should have a rubber plug that goes into it with what looks like 3 holes, 2 are vacuum lines, the other is just a plug. I don't remember where they go.
Old Jul 19, 2004 | 02:47 PM
V6sucker's Avatar
Engine: blown up
the thing is I gave where they went in the other tread.
Old Jul 19, 2004 | 04:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, it's a triple post. rsttop, did you ever follow up on the help that Rbob gave you back in March 2004? Your old message is here: https://www.thirdgen.org/techbb2/sho...postid=1746003
Personally tho I can't stand that GM didn't put the vacuum diagrams inside the GM service manual!! They always say "look at the hood sticker"- I haven't had a hood sticker since 1995. (sigh)
Old Nov 18, 2024 | 01:10 PM
Bluemr88's Avatar
Re: 3.1L Vacuum Lines
Old Nov 18, 2024 | 01:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
20 years later 😆
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
