EST problem, timing not advancing...
Old Jul 27, 2004 | 02:17 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Ok, last saturday my car stubled and fell dead on me. I have no codes in the memory. I went ahead and put a fresh starter and battery in (heat soak issues are sorta non-existant now, free parts ROCK). Anyhow, my car has a stuble at idle now that started about 2 weeks ago (I got a code 43 one night while cruising, so I replaced my O2 sensor, seeing how I had another one laying in my trunk). Code went away of course (light wasn't permanently on, just in the memory). Anyhow, now the car stumbles at idle, and has a tendancy to die at lights. When I hook the Snapon scanner up, it shows No timing advance.... Timing is in the only position where it will run "properly", by that I mean make power (quite advanced). It doesn't ping or backfire, just has a stumble at idle, and scanner says 0* advance, even at part throttle ??? I went ahead and replaced the ICM (old as heck, need a change), didn't soolve the problem. ANy ideas, or people with similar problems, HELP. thanks as usual!
Old Jul 27, 2004 | 04:11 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
You forgot to reconnect the tan EST bypass wire, the EST bypass wire is broken somewhere, or the EST signal wire is broken or shorted. ICM if it weren't brand new.
Old Jul 27, 2004 | 04:54 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
could ur equipment be messed up? check to make sure the EST bypass wire is connected, then hook a timing light up to the car, and give her a little gas...should see your timing increase off the chart.
Old Jul 27, 2004 | 06:36 PM
FbodTrek's Avatar
It isn't the wire, it's shielded and connected. That's a good Idea though 85f-bird, I'll have to do that tommorow (had enough of cars today). I really need to find out why the motor is stumbling at idle though. I thought that the timing had somthing to do with it, but I doubt it. I just hope it isn't a mechanical issue (if it was, I figured the problem wouldn't go away at part throttle like it does). Fuel pressure is good as well. I guess I'll go ahead and swap out my "backup" ECM, even though it's not coding, I suspect eectrical issues. That Edelbrock manifold and 4bbl setup is looking VERY tempting.
Old Jul 27, 2004 | 08:14 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Tell that to my buddy whose timing jumps ~20 degrees if you supply +12v to his OE cooling fan power lead. The way you seem to have said this is "Nah, that just can't be it" rather than "I've spent 20 minutes with a DMM checking this already." If I'm wrong I apologise
Old Jul 27, 2004 | 08:53 PM
FbodTrek's Avatar
Note taken..... I'll check it tommorow (just to make smurf happy )
Old Jul 28, 2004 | 04:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How is the EST wire shielded? Did you add shielding?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
