belt tensioner pully noise?
Old Jul 29, 2004 | 12:39 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Im hearing some noise coming from the belt tensioner pully. ive checked around it to see if anything was lose but theres nothing. this noise seems to occur only when the car is in drive and im stoped at a ligt. somtimes i hear the noise in park. do i need to change the tensioner pully or what? does it need some oil or what around it? its getting realy irritating to me guys pleas help. thanks
Old Jul 29, 2004 | 01:23 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What kind of noise? Pulley bearing could be going south.... or a loose belt. Look at the indicator on the tensioner - is the belt too stretched?
Old Jul 29, 2004 | 03:04 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
didnt know the pully had bearings thats interesting. the noies is like its lose . hard to compare it to somthing. its not lose ive checked. but its like a small clank, clank clank noies. its not hella loud but you can hear it. should i take it off? what am i looking for at the indicator and what does that tell me? can this thing be tighten and bearings replaced?
Old Jul 29, 2004 | 04:40 PM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
Take the belt off and spin it... and any other pullys ... see if you hear the noise then... and you will know which one... Also is the noise only when the a/c comprssor is on? If so it could be the A/C comprssor clutch
Old Jul 29, 2004 | 05:08 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
the tensioner is made up of 2 different systems.
1 A large spring, that once begins to break, can give off "popping" noises.
2 A axial bearing for the actual pully. Once that begins to go you hear a scream, or intermitant scream.
My suggestion is if you decide to remove the tensioner, already have a replacement handy. Because if the internal spring is breaking apart, you will not be reinstalling it.
Old Jul 29, 2004 | 08:01 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
its not coming from the a/c. so can i get a pully from a local parts store?
Old Jul 29, 2004 | 10:27 PM
V6sucker's Avatar
Engine: blown up
typically yes. I think mine was around 15-20 last time I replaced it. 2-3 years ago?
Old Jul 29, 2004 | 10:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Why not just replace the whole tensioner, a new pulley comes with it.
Old Jul 30, 2004 | 11:45 AM
V6sucker's Avatar
Engine: blown up
I think tha is what he meant. At least lets hope that. Anyway you cannot get the 2 parts seperately anyway.
Old Jul 30, 2004 | 11:52 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Actually you can buy the pulley seperately, they carry them at most auto parts stores.
Old Jul 30, 2004 | 01:17 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
is the tensioner easy to replace? once the tensioner is off does the pully go off right along withit? it seems like there is only 2 bolts that come off the tensioner.
Old Jul 30, 2004 | 02:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Mory,
There is only one bolt holding the tensioner in place along with a metal tit on the back of the tensioner and one bolt holding the pulley to the tensioner. You can remove the pulley without pulling the tensioner off. However you will have to pull the belt whichever way you decide to go. If you plan to just change the pulley, it is a good idea to break the torque on the pulley bolt before removing the belt. It is not a neccessary carved in stone thing to do, I have just found it makes the bolt removal a little easier by breaking the torque first. Sort of like the lug nuts on a tire.
Old Jul 30, 2004 | 04:27 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
can you send me a picture so i can get a better idea of what im breaking sir.
Old Jul 30, 2004 | 05:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
But of course I can Mory. In this picture, #1 is the TORX bolt that holds the tensioner to the bracket and #2 is the bolt that holds the pulley to the tensioner arm. The figure in the upper right of the picture shows the wear indicators on the tensioner. Hope this helps you!!!!!!! BTW, the square opening at the top for the breaker bar or ratchet adapter will be either 3/8" or 1/2" depending on manufacturer.
Old Jul 30, 2004 | 08:01 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
thank you sir and all th rest of u gentelmen.:lala: :lala: :hail: :hail: :lala:
Old Jul 30, 2004 | 11:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You're more than welcome Mory!!
Old Jan 14, 2019 | 03:31 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Re: belt tensioner pully noise?
The "#2" bolt that holds the pulley wheel to the tensioner arm. That just simply unscrews? Its as simple as putting a wrench on the bold and removing it?
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
sjorgens
Oct 1, 2015 07:54 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
anesthes
Sep 30, 2015 07:48 AM
kitt23
Sep 26, 2015 07:48 PM
