dead??? i hope not
Old Aug 14, 2004 | 11:32 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
dead??? i hope not
Ok so do to the hurricane that we had, and what Virginia beach felt of it, I had no choice but to drive my car part of the way through a flood, whelp water up to the doors and no stall, however when I decided I had better not progress anymore that I already did I made a turn and the street I was going to park my car on completely covered my nose in the firebird for a bout 7 seconds and then I was able to get it to a stopping point while it was still running.
Now for the bad part/question; I went back to the car right after I walked the rest of the way home to get some shorts on and when I went back I took off the intake air hosing up to the plenium and there was a spot about little less of .5 oz of water sitting on the plenium nose just after the plastic intake hose.
The car would turn over but it couldn’t start I’m pretty sure it was flooded with water. Tomorrow I hope it will start.
If I’m not mistaken isn’t HYDROLOCK when your motor will not turn over at all or did I possibly HYDROLOCK my baby. It will turn over and almost start up but it just couldn’t do it.
So please tell me if you think I have killed her.
I'll definately post how it goes tomorrow.
Old Aug 14, 2004 | 11:39 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
If it turns over that is good. Hydrolock stops the motor completly (and if it was running, bend rods). You probably just flooded it with water.
Old Aug 14, 2004 | 11:44 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i hope so man, i love my car and just dropped some serioius money getting the tie rods done (i have a new baby no time)
Old Aug 15, 2004 | 03:00 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
i heard pouring desielfuel into the spark plug holes will loosen up a flooded motor, stuck rings, or a motor that has been sitting for long
Old Aug 15, 2004 | 03:30 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yeah, you really want to take out your plugs and turn her over for a bit *before* you actually try to start her if she sucked some serious water...
Old Aug 15, 2004 | 03:36 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
ok cool the car runs however it doesn't idle anymore it quits so think it may be search time since i just replaced the tps think i'll try IAC
Old Aug 15, 2004 | 05:35 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
If it ran fine befor. I do not recommand yet throwing parts at it. Change the oil just in case. Then run the car, let it heat up good, spray a lil carb cleaner in the throttle body and clean the IAC. Then run it more. Prob should go away unless water damaged something. Good luck
Old Aug 15, 2004 | 11:39 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
That sounds like a good place to start. I second that. If you got water in the engine, change the oil. You might want to flush it too.
Old Aug 16, 2004 | 06:05 AM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
If you would like to add either some marvins myster oil or even better (but a lot more expensive) Some Lucas oil. It has worked wonders in cases like this. It cant hurt to add a quart of this stuff when you change your oil. You can get either one at most parts stores. Although the Lucas oil comes in 1 gallon bottles.
Old Aug 16, 2004 | 07:34 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
:hail: Lucas have used that many times IT WORKS, but luckily after sitting overnight at the tire place it runs fine just needed to rest and dry off a bit more, it runs and idles now............the car gods are smiling upon me this morning:lala: :lala: .............so if anyone ever wants to talk crap about the car i can now say that i have completely su nose in subbmirsed the nose in water and all she needed to do was dry off and a new air filter, of course the old one dried out but hey its the least i can do for the car after getting me home to my newborn on saturday..
Old Aug 16, 2004 | 09:06 AM
Car: 89 firebird
Engine: 2.8
Transmission: auto
Hey alright! Good luck with the car and congrats on your newborn!
LC2 TECH
Oct 13, 2015 11:53 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
3.8TransAM
Oct 1, 2015 07:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
